Cheap way to drill a deep hole in aluminum?
Page 1 of 2 12 LastLast
Results 1 to 20 of 31
    Feb 2004
    Napa, CA
    2,641
    45
    705
    Default Cheap way to drill a deep hole in aluminum?
    I'd like to drill a 1.25" hole in 1.75" aluminum round bar, about 10" deep, blind hole. Hard to find drills that long, I guess gun drilling would be the classic approach but I don't have that set up. Prototrak lathe or Deckel mill is what I have. Are there long bits available, or some easy way to do this? Tolerances are unimportant.
    Feb 2020
    Alabama
    260
    97
    69
    Amec spade drill.
  3. Likes PegroProX440, SIM, Jashley73 liked this post
    Jul 2006
    Hillsboro, New Hampshire
    12,422
    2845
    8634
    Yeah, if you really want to keep it cheap, buy a spade drill insert and make your own quik-n-dirty body for it.
    If you have coolant on the lathe, you could buy some heavy-wall 1" tubing for the drill body, mill a press-in (or welded) head, then plumb coolant through the center.
    Aug 2006
    greensboro,northcarolina
    2,604
    179
    692
    Beat me to it.
    https://www.mscdirect.com/product/details/79731782
    Cheap compared to what?
    Sep 2005
    Oakland, CA
    2,899
    511
    894
    Ya don't need a spade drill to do that. Buy a Silver and Demming 1/2" shank twist drill and make a cheapo extension out of some 7/8" or 1" diameter rod. A 1/2" hole in the end for the drill shank and a few set screws and your good to go.
  7. Likes RJT, jaguar36, Bobw, gustafson, 3t3d and 4 others liked this post
  8. #6
    Apr 2007
    Pillager, MN
    6,225
    1925
    6024
    How many holes? 1? 1000?.................for a couple and I was really on a really limited budget and only need a few holes.............^^^^^^what Dan said^^^^^^....................
  9. #7
    Sep 2002
    People's Republic
    5,795
    696
    3633
    And I would mount it to the carriage so once you get past the flutes you can rapid it out o the hole quick
  10. Likes Jashley73 liked this post
  11. #8
    Feb 2020
    Alabama
    260
    97
    69
    Quote Originally Posted by Dan from Oakland View Post
    While you're at it, hand make all of the screws, make your own S&D drill, forge a rod out of some old horse shoes laying around the back yard. In manufacturing, time is money.
  12. #9
    Jul 2006
    12,422
    2845
    8634
    Quote Originally Posted by CORONA VIRUS View Post
    This reminds me of the guy who posted here a year or two back about wanting to buy his own screw machine so he could save time and money by not having to go to the hardware store for bolts and such.
    I wonder how that worked out for him?
  13. Likes CORONA VIRUS liked this post
  14. #10
    Sep 2007
    Washington
    5,649
    268
    1878
    No gundrill outfits in Napa?
    Regards.
    Mike
  15. #11
    Jul 2006
    12,422
    2845
    8634
    Quote Originally Posted by Finegrain View Post
    Regards.
    Mike
    The man said "cheap".
  16. Likes Bobw liked this post
  17. #12
    Feb 2004
    Napa, CA
    2,641
    45
    705
    Alright, thanks for the suggestions. I only need to do two holes (plus the ones I screw up). There isn't much of any machine industry in Napa - I probably am the second best equipped shop in town .
    I'd searched on MSC which didn't produce the spade bit results for some reason (that reason being the MSC website sucks). The spade bits would be in budget, I do have coolant, and I might try the S&D with extension idea though I imagine it will require about a million pecks.
    On a 1 1/4 hole with the spade do you just drill it in one shot? or pilot drill?
  18. #13
    Jun 2009
    NE Ohio, USA
    72
    68
    Contact Allied Machine. I just drilled 56 - 1.562 dia. x 9.7 deep holes. 6061 Alum, coolant through drill in a VMC. G81 for 1st hole. Spindle load went up to 80% around .5" from final depth. It stayed at 35% until then, I'm thinking chips not evacuating. The rest of the job was with a G73, Q of .100". Horizontal drilling will be much better. No pilot, just spot drill. ------------ John
  19. #14
    Jul 2006
    12,422
    2845
    8634
    If you use a spade, you might be able to power feed with the carriage if you plumb coolant to the drill body. Even low PSI may be enough if you play with the feed to get the right chip formation.
  20. #15
    Apr 2007
    West Virginia
    1,312
    808
    568
    Figuring out affordable tooling for small jobs is a challenge I can relate to.
    Yg1 spade drill components are more affordable. I’m no spade drill expert but I believe no pilot and no pecking is preferable. But you need the coolant pressure to get the chips out. If coolant pressure isn’t quite enough then peck. And if it’s not breaking chips it’s better to peck.
    I had a few deep holes in stainless. Not quite enough coolant pressure couldn’t get it to break chips with what I had. Got through by pecking. Very small pecks.
  21. #16
    Jul 2006
    12,422
    2845
    8634
    If you have the option of which Al to use, you might try 7075 rather than 6061. It's harder, cuts more cleanly, and you should get actual chips rather than strings or clumps coming off the drill.
    The other thing you might look for are the types of spade inserts with the slots at the edge that act as chip breakers. Especially as you'll have low coolant pressure from a regular pump, the slotted cutting edge should help generate smaller chips (even if you have to use 6061).
  22. #17
    Feb 2005
    9,573
    16127
    11619
    Or 2024.
    I've never had a melt down with either 2024 or 7075, and I've tried.
    Double the price, but a lot easier to machine. I prefer 2024, it doesn't
    stain as easy as 7075. You look at that stuff wrong and it changes color,
    don't ever leave it in the vise overnight wet with coolant.
  23. #18
    Langley, B.C.
    1,848
    407
    1081
    Seems like a lot of fuss for a couple 10" deep holes. Why not use a plain morse taper socket extension?
    An 1-1/4 MT3 drill should get you 7"-8" of depth and a MT3 to MT3 extension should get at least another
    3"--there's your 10" depth. Extensions are 25-30 bucks and I'm pretty sure they'd be less than 1-1/4"
    in diameter so there would be clearance down the hole. For a bunch of holes I can see some more
    "elegant" solutions but we're only talkin' two holes here...
  24. #19
    Feb 2007
    Aberdeen, UK
    4,498
    1632
    2079
    Honestly, Korean spade drill bodies are so cheap I'd have to be really desperate to save money and have lots of spare time before I'd do that.
  25. #20
    Mar 2017
    LATVIA
    755
    209
    443
    I realize the question was how to drill, not how to make the end product, but I have to ask - can't you start with a tube? I did a quick search and see that extruded tubes are available in 1.75"OD 0.25" wall size, then either weld a cap or thread in or on a plug, making a tube out of solid seems like a waste of resources, especially since ready made tool will be expensive and making custom one still will take time and a drill to start with...
    edit, in absence of TIG or other welding method, even propane torch with aluminum brazing rod would do
  26. Likes digger doug liked this post
