dandrummerman21
Stainless
- Feb 5, 2008
- MI, USA
I have this job that keeps repeating and quantities get higher and higher. Each part has 8 2.5" (drilled depth) deep M20 tapped holes. The tapping I have down. But the drilling sucks
I have tried solid carbide (not TSC at the time) and after it chips, it quickly went to hell and I had to dig carbide out. With that in mind, I do NOT want to get TSC carbide drills for this job. The quantity is still low (I only have about 150 holes to drill this run) and I do not want to wreck 250$+ drills until I find a sweet spot. I want advice about going forward with HSS only. I also tried a spade drill with cobalt insert but wrecked the insert and body after only a few holes.
With that out of the way, I did snag some oil hole drills from ebay. 11/16" diameter. One is PTD HSS and the other is Nachi M42 Cobalt. I have thru spindle coolant.
So, here are pictures of the drill that I ran this job with last. It was HSS, maybe PTD/Dormer but not sure the brand.
Yes, I just pulled that drill out of the machine. It successfully finished drilling a part to depth looking like that. Honestly it probably sounded better than when resharpened. We resharpen big drills like this in house.
This was running a G83 cycle at 220rpm (40sfm), .9ipm (.004 per rev), and a .060" peck
I think the full out pecking is causing the chip to have to break, but its gummy ass stainless and it doesn't want to break, so it rips the edge off the drill.
So where should I go from here with the new drills? I have thru spindle coolant, so i was thinking I could have a short retract with G73. Or hard code pecks where it doesn't retract, but just pauses a couple revs so the chip breaks. I am almost certain I wont be able to get the chips to break by feeding it hard.
Can I go faster (both SFM and chipload) with the new drills because i have coolant at the tip? Should I G73 it or have it pause or slowly feed back a few thou to break the chip? What would you do?
I will also add, I want it to be reliable, and it doesn't need to break speed records. I don't care if it takes several minutes a hole. As long as it is reliable and predictable. I can change the drill every few parts as needed.
