Liberty_Machine
- Feb 28, 2017
Doing some aggressive milling of aluminum, long running production job. There are pockets in the part, and the way the high pressure coolant hits some of them, it sends chips right up into the toolchanger on my DuraVertical. It's been running okay for over a week, but I just had 4 parts come out (fixture holds 4 pcs) and some of my blends went to shit. Inspection of every tool revealed a couple holders as having chips on the flanges (dual contact), throwing things out of kilter. 99% certain that the chips came from the issue mentioned above. The solution, it seems, is to rig up some sort of door that I tie into the control. I know it adds cycle time, but I'm already pushing 4 hours per run. What's a couple more minutes....
The quick solution is to just pre-call to an empty pocket and let that take the brunt of the chip spray. I've made that change to the program, running my 4th batch of parts now. So far, so good. If that doesn't work out, I'd like to have a "Plan B"
Anyone ever done this? Fools errand?
I will say, that is one of the attractive features of the Doosan mills, in that they DO have a door.
I did run some YCM NXV machines at my last job that had brushes installed at the tool opening. Those seemed to do a decent job, although we were never running serious levels of production on them...
