Chopped Up Finish - Indexable End Mill on AL
Page 1 of 2 12 LastLast
Results 1 to 20 of 35
    Dec 2019
    43
    16
    Default Chopped Up Finish - Indexable End Mill on AL
    Bought this end mill and these inserts to face a 1" wide surface, 6061. 1400SFM & IPT of 0.004" for an RPM of 4278 and a feed rate of 34ipm, DOC of only 0.01". Needless to say, the results were not as anticipated. I'm fairly new to machining, so it wouldn't surprise me if I had the inserts backwards or something ridiculous (I don't really think I have the inserts backwards ). WTF!
    Jan 2019
    Arizona
    903
    82
    328
    Quote Originally Posted by sdinzy View Post
    Aside from the tool being a POS your set up is the main problem. its not rigid
  3. Likes Bobw, Dualkit, PegroProX440, Bluejeep, Mtndew and 2 others liked this post
    Dec 2019
    43
    16
    I thought it might be the workholding. I would agree the tool was cheap. Ok so final verdict is workholding?
    Apr 2018
    3,973
    1794
    That and those inserts. C'mon, just a regular nose radius is fine. Big broad contact surface like that is going to create problems for anything but a perfect setup.
  6. Likes Bobw, Illinoyance liked this post
  7. #5
    Dec 2019
    43
    16
    Honestly I don't know anything about inserts. Please educate me.
  8. #6
    Oct 2013
    New Jersey
    1,176
    1002
    So I am no machinist either, but I can tell you that a flat faced insert like that is going to push off like crazy and if the part isn't absolutely ridid you'll get what you gotten. Use a nice new dead sharp end mill and you'll get much better results. It's aluminum and you will likely break it from stupid long before you wear it out. A smaller tool won't push as hard either so it will reduce the rigidity problem.
  9. #7
    Feb 2005
    9,215
    14839
    11028
    If its a TPG.. DO NOT buy it. Quite honestly, they should be outlawed. 1960's left over
    garbage that even most home shop harry's won't even use anymore. Flat top, no geometry,
    just garbage.
    And if you paid anywhere near those prices, you got gang raped. But.. That is MSC's standard
    operating procedure.
    Even a standard APKT (80's technology) will work far better.
    1 INCH APKT END MILL
    And I'll agree, to get that kind of chatter, your work holding had to be sketchy.
    Learning experiences. Aren't they great?
  10. Likes Jashley73, Illinoyance liked this post
  11. #8
    Jul 2006
    Hillsboro, New Hampshire
    8,970
    2151
    6220
    That style of insert cutter is essentially the worst thing you can use aside from bolting rocks (well, pebbles) to holder and trying them.
    But forget that for a moment, you need to show us (in the machine) how you were holding the part.
  12. #9
    Dec 2003
    poulsbo, wa, usa
    975
    71
    426
    shear hogs from ABtools.com or Ripper mills from Latheinserts.com
    I run both and have for years on alum with great luck ,, but I well say with the finish your getting it has to be a bad setup as much as wrong tooling for the material.
    I have also had good luck with the cheap-O face mills from Latheinserts.com ,, he has some alum inserts that seem to hold up for months and you cant go wrong on them for like $7 each ,,, I have one mill setup on a nonstop production part and its been a year on the same inserts and the finish it still holding ...
  13. Likes Bluejeep liked this post
  14. #10
    Apr 2005
    Beaverdam, Virginia
    8,144
    916
    3923
    Like others said, post a picture of your set-up. It looks like you had something that would flex and vibrate like crazy, even with the proper tool. I could not image the noise it was making.
  15. #11
    Dec 2019
    43
    16
    Hi Guys, Thank you for all the responses. The workholding itself is actually fine (5th Axis dovetail fixture), it’s just that due to the order of operations, the remaining extrusion supporting the part being faced provides very little rigidity; I can easily change the facing operation to occur much earlier in the process. *The sound actually wasn’t bad, relatively*
    In regards to the inserts, thank you all for the wisdom. I tried researching inserts to the Nth degree prior to purchasing, but it just doesn’t seem to be a topic you can read about online. If any of you can recommend a product or type of product in order to point me in the right direction, I would greatly appreciate it! I don’t necessarily need a mirror finish, but the current finish won’t work ;-)
  16. #12
    May 2002
    South Central PA
    13,835
    2405
    3645
    +1 to throw that tool away, they weren't very good when they were young, and now they are antiques.
    No one has mentioned edge prep. Since the grade is listed as C5/C6 whatever that really means, it's probably a generic grade intended for steel, so it probably has a honed edge. Search here for edge prep for more explanation. An aluminum insert usually has a dead sharp edge with no honing, honing will make aluminum smear and will make an otherwise good cut very ugly, and make the part push away, and cause build up on the edge of the insert which makes even more trouble.
    +1 on the ripper mills from latheinserts.com, they are more than worth the investment.
  17. #13
    Sep 2014
    Georgia
    603
    8
    109
    You are better off with a Chinese $40 apkt insert mill. I have never used anything with those old school inserts and I’m pretty impressed that you were able to buy them. You own a modern looking 5 axis machine. Sounds like you have some decent $$$ try calling a tooling rep for whatever brand you want.
  18. #14
    Apr 2018
    3,973
    1794
    If you don't feel like throwing it away, get a box of cheap inserts that have a normal nose radius, instead of those wide flats. Standard old TPG-322 or something. Uncoated.
    Yeah, it's not a great tool but if you hold the part so it doesn't shake rattle and roll, and use an insert with a standard nose radius so the contact patch is small, you should be able to make it work.
  19. Likes Perry Harrington liked this post
  20. #15
    Sep 2015
    Ohio
    1,279
    850
    1287
    Looks like you have a 4 maybe 5 axis mill? I'd try machining that surface with the side of an endmill.
    You might get a little funkiness at the beginning and end of the cut, but once the tool is into the cut it stays engaged. Not like the constant pounding it's getting from that inserted tool.
  21. Likes Bobw liked this post
  22. #16
    May 2019
    Michigan
    893
    101
    344
    Try Ingersoll's HiPos Alu line. They have a crowned back to keep the inserts seated at high speeds and a sharp polished cutting edge. They will make that TPG tool look like Stone Age technology.
  23. #17
    Dec 2019
    43
    16
    Thank you Chip! It sucks buying stone age $hit not even knowing it was stone age $hit, but all part of the process I guess.
  24. #18
    Jun 2012
    Michigan
    5,100
    4657
    3076
    Go to all of the big name websites and download their literature or have them ship you a physical copy of their books.
    Sandvik,Iscar, Kennametal, Mitsubishi Carbide, Seco,Garr, etc... they all have info on their tooling and their recommendations.
  25. #19
    May 2019
    762
    235
    334
    Despite the tool being a far less than optimal geometry it is capable of producing a far better finish than that. Something is loosey goosey. Likely the part but maybe something else. Hard to tell without more pics.
  26. Likes Bobw, Perry Harrington liked this post
  27. #20
    Mar 2017
    LATVIA
    516
    133
    262
    how about showing how the part was held down? that end mill, even with "no geometry", cannot be solely responsible for that result
  28. Likes Bobw liked this post
