Chopped Up Finish - Indexable End Mill on AL - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
  1. #21
    Mar 2008
    vacaville ca
    479
    67
    130
    even shitty inserts should have done better then that, are you running the spindle backwards?
  2. Likes Bobw, cameraman, Mtndew liked this post
  3. #22
    May 2019
    Michigan
    906
    107
    350
    You need to sell that as a "deep textured jeweled surface" @ $5.00/ square inch. I honestly didn't know it was machined the first time I looked at it......
  4. #23
    Dec 2019
    43
    16
    Thanks for everybody’s help (and jokes, def joke worthy). Bought a Kennametal Dodeka 45 Mini plus Kennametal inserts for both Al & steel. $800 later this better be a nice finish :-D
  5. #24
    Jan 2019
    Arizona
    905
    82
    328
    Quote Originally Posted by sdinzy View Post
    you wasted your money on thise particular project as your problem was the set-up not the tool. now you will just get a $800 + material and time scrap part rather than a cheaper one.
    another words your just putting lip stick on a pig
  6. Likes Mtndew liked this post
  7. #25
    Dec 2019
    43
    16
    Quote Originally Posted by Delw View Post
    As I mentioned earlier, changing the order of operations so that the part was more rigid when this facing occurred is/was easy, and this new Dodeka is working great.
  8. #26
    Feb 2014
    FL
    3,331
    11489
    3753
    Got pictures?
  9. #27
    Aug 2015
    Illinois
    1,490
    1092
    635
    Regardless of others opinions, keep the TPG face mill. Use it for cutting down weld beads or flame cut edges or other hard spots. The TPG inserts may break, but they are the cheapest available. Basically, use the TPG where you are afraid of trashing a quality face mill with expensive inserts.
  10. #28
    Oct 2006
    Klamath Falls, Oregon
    3,680
    432
    1020
    Your original TPG insert looked like wiper inserts with a very large wiper interface. The theory is good, but application is questionable. I agree that you can salvage this cutter with some bog standard TPG-322 or 321 inserts. Hacking down welds and other grungy machining is the province of these inserts. I inherited a crapload of them with some machining stuff I bought out of the gate, the machine equipment was from 1984 and I think most of the tooling was too. I did a lot of boring with a TPG-322 Kennemetal boring bar, it worked fine and is a good tool for a manual machine.
  11. #29
    Jan 2019
    64
    5
    Quote Originally Posted by D.D.Machine View Post
    shear hogs from ABtools.com or Ripper mills from Latheinserts.com
    I run both and have for years on alum with great luck ,, but I well say with the finish your getting it has to be a bad setup as much as wrong tooling for the material.
    I have also had good luck with the cheap-O face mills from Latheinserts.com ,, he has some alum inserts that seem to hold up for months and you cant go wrong on them for like $7 each ,,, I have one mill setup on a nonstop production part and its been a year on the same inserts and the finish it still holding ...
    can either of you two hit on the surface finishes attainable by the ripper mills? that is my MAIN focus looking into a new facemill.
  12. #30
    May 2002
    South Central PA
    13,836
    2407
    3645
    Quote Originally Posted by sirAIG View Post
    Rippers make a VERY smooth finish. I can see swirls on the surface but can't detect any by feel. Sanding with 600 on an orbital sander doesn't pick them up either.
  13. #31
    Jan 2007
    Flushing/Flint, Michigan
    8,660
    467
    7108
    Why would you put these inserts in this endmill body?
    Someone recommend this to you? Did you want to make your life difficult?
    Or just did not know or understand and bought the first you found?
    Bob
  14. #32
    Jul 2006
    Hillsboro, New Hampshire
    8,997
    2155
    6241
    I gotta weasel out with saying that it's much more dependent on fixturing and programming; given time and some money I could give you the part you showed cut with your original tooling and it would be quite smooth. But if I had a foreman or boss they'd be yelling at me for the time I took to get there.
    Good thing I'm my own boss, so the only folks who yell at me are my customers. Uhh, crap...
  15. #33
    Jan 2019
    Arizona
    905
    82
    328
    As i mentioned earlier changing your setup and for 800 bucks less you could have had a perfect finish
  16. #34
    Jan 2019
    64
    5
    I'm not OP Chopped Up Finish - Indexable End Mill on AL
    Sent from my SM-G955U using Tapatalk
  17. #35
    Oct 2006
    3,680
    432
    1020
    Those high shear tools also generate a lot of upward pull when cutting. To get good results it's even more important to have a rigid setup. I have a Shear Hog and have used it on a variety of projects and alloys, it's extremely important to restrain any drops and prevent the part from flexing. The finish can be quite good, but feeds and speeds are critical to performance, as well as the nose radius.
