Chuck adapter for Rotary Table
Likes Likes:  0
Results 1 to 3 of 3
    Feb 2005
    Fishersville VA
    2,036
    61
    146
    Default Chuck adapter for Rotary Table
    Going to add a 10" Bison onto the 12" Koma table.
    McMaster has cast iron and aluminum discs.
    To me cast seems better, then rotary, adapter and chuck are all the same material.
    Wonder if Alum corrodes over time??
    But you guys have been in CNC whole lot longer than me.......
    So which way to go?
    Oct 2009
    Oregon
    7,175
    7714
    4448
    Make it from iron or steel.
    There's lots of ways to do it, but I have one 12" rotary that was ordered with all the bells and whistles and the way it (Yuasa) came from the factory with a chuck was you swap the t-slotted faceplate out for a chuck back plate that bolts straight to the spindle. Then the chuck bolts up and you can dial in the chuck with set screws. It's real important that there's a method in your mounting to dial in a 3 jaw- Like the set-tru style mounting with 4 set screws. Totally useless to put a shaft in a 4th and have it run out .01".
    I use a trunnion on the 4th 100:1 over the chuck.
    Apr 2007
    West Virginia
    1,635
    1049
    716
    I just did this more or less. In my case the rotary doesn't come with a face plate so I made one to mount a vise on. I chose ductile iron from McMaster. It machines very nicely. I just don't think aluminum is a good choice for a permanent fixture.
