OVER HIGH LIMIT
- Oct 3, 2017
We have an okuma crown cnc lathe in our shop that I love but the open/ close prox switches drive me crazy when im flipping matl. anyone know how I can override or wire around this issue? thanks
The only thing you can do is cut your jaws so that the chuck closes to the same general spot on both ops.
I hate those stupid switches. We used to share jaws between machines, so you could never count on the chucks closing to the same spot. We were constantly adjusting them. I wish they just had a pressure switch like other builders.
Drawtube proxes are set and forget, not adjust as required. Seems it's incredibly common for people to not understand how they work, and be constantly messing with them.
They are NOT there to tell the control that the chuck is clamped in exactly the right position of travel.
They work in conjunction with a pressure switch.
The pressure switch tells the control the chuck is closed. The prox switch tells the control the jaws are not bottomed out in the chuck body - if they are set correctly.
Once set correctly, the only reason they should ever need adjusted is if the drawtube nut backs off - which is also a good indicator of if the drawtube nut has backed off...
Have you ever used an Okuma or are you just making this shit up?
Any time you switch from ID clamping to OD clamping, the prox switches have to be swapped. In my old job, almost all first ops were ID clamping. Almost all second ops were OD. The operators could expect to change the switches several times each day.
Did you check for a small pc of Schidt on the surface of the prox?
Think Snow Eh!
Ox
All the Okumas I ever ran required the prox switches to be adjusted for each job, depending on how far the drawtube moves to clamp the chuck. I can't recall ever seeing another brand of machines setup the same way.
One a Mori Seiki or something, they typically monitor chuck pressure or use a prox switch that tell the control the chuck has moved from fully open or fully closed. The Okuma is more picky.
Notice
