Cincinnati Milacron Avenger 200MS 1994 with Acramatic 850SX Not powering up operator contol
First and foremost:
Thank you for all input in advance. Normally I have called up the factory, however since COVID started all the knowledgeable people are no longer there and these machines are “No longer Supported”. Plus I’ve not needed to diagnose machine breakdowns with the manuals. So I feel green to machine repairs now.
My Control Screen/Monitor doesn’t show anything. I turn the main power on using the main switch on the electrical cabinet. Then press start on the operator’s control panel. I do see components inside the electrical cabinet starting up so the button is engaging something however I do not see any of the buttons light up for a second like I’m used to seeing and then there is not “Host Control Initializing” viewing on the screen. The screen actually looks like it’s not functioning, however I doubt the actual screen went out because the buttons should still light up.
Any directions or sequences you could point out would be appreciated. I believe I have most of the repair manuals and am going to start looking at them in a day or so, however I thought I would see if others have had this issue.......or I'll have started a Thread for future issues on this.
Thank you,
Rosie
First and foremost:
Thank you,
Rosie
