Hello! First post on the forum.
We have multiple Fanuc Robodrills, however the one in question is rather old, a T14iA with a 16i controller. When running a program with G03 the feedrate varies wildly during the arcs, rather than staying at a consistent speed. On the newer Fanucs with 31 controllers, they run the same program smoothly with consistent feedrates, leading to faster cycle times.
The newer Robodrills do show AICC active while running, but I'm not sure if that is what's causing this. Is there a parameter I should be looking for that's inhibiting the 16i machine's feedrate?
Thank you.
Thank you.
