Circular milling a tapered hole
Results 1 to 20 of 20
    Mar 2016
    AUSTRALIA
    6
    Default Circular milling a tapered hole
    Need help machining a tapered hole starting at 28mm dia tapering to 19 dia 38 deep. Am using fanuc 18i control and thinking macro or g code . Any sample will do. Cheers mick
    May 2016
    Ohio
    568
    158
    183
    Here we go
  3. Likes aj liked this post
    Sep 2002
    People's Republic
    4,385
    420
    2670
    What does your finish need to be?
    I'm not gonna do the math, is it a particular taper?
    i did a tapered off center[center of top was not same as center of bottom] hole on a bunch of parts for a friend years ago. Ball end mill, lots of coordinates, lousy finish
    CAD/CAM is the way to do it
    Jan 2014
    Temecula, Ca
    3,191
    1379
    4167
    does it need to helix in the opposite direction in Australia?
    Your description doesn't help much. Can you use a tapered end mill?
    5 axis swarf cut?
    Keller?
    Feb 2013
    Idaho
    755
    170
    868
    What are you talking about... it's only three lines of code to make a tapered hole. Z -38.0, and A-10.0, and then a B 360.0
  7. Likes Booze Daily, Garwood, Ox liked this post
  8. #6
    May 2019
    Michigan
    752
    62
    284
    solid carbide feedmill
    really really fast feed
    really light doc
    like **** down the toilet........
  9. #7
    Sep 2002
    People's Republic
    4,385
    420
    2670
    Quote Originally Posted by G00 Proto View Post
    not a vertical hole
  10. #8
    May 2019
    Michigan
    752
    62
    284
    not a vertical hole
    He's programming for a 5 axis machine.
    spoiled kid.
  11. #9
    Sep 2002
    People's Republic
    4,385
    420
    2670
    Quote Originally Posted by ChipSplitter View Post
    spoiled kid.
    huh?
    2 1/2 axis machine
    tapered hole, one side vertical.....
  12. #10
    Apr 2020
    Wisconsin
    9
    Given my experience if you are trying this in a three axes milling machine, and you need a finish better than a 120(not sure what that is in metric)your going to need to get a custom solid carbide tool made. First come in with an insert drill that will leave stock for the minor diameter. Next rough the taper in the hole with a ball mill by just stepping it down say .5mm or something, just doing simple circles with decreasing diameters. Than come in with the finish tool. if you have a lot of parts/holes you may want to get 2 finish mills, one to semi rough the part, the last to just kiss it and bring it in to tolerance. Be sure your grinder leaves enough flute on the tools to allow you to change your offsets without milling a straight/rubbing the shank as you get your setups dialed in.
    I hope that is helpful.
    Our shop makes some steering rack linkages assemblies that have taper holes in both faces(5 each part). Mat. is 4140 heat treat. We have done this on 1000s of them. They assemble like clockwork all day. Your nominal dimensions are really close to what were doing.
  13. Likes Greg White, digger doug liked this post
  14. #11
    May 2019
    Michigan
    752
    62
    284
    Quote Originally Posted by rorycollins0 View Post
    I agree.
    If the OP is doing high production it puts it into a different realm altogether.
    In that case a custom form tool would be the cat's meow.
    BTW according to my calculations the angle would 6.75 deg.
  15. #12
    Mar 2016
    AUSTRALIA
    6
    They wont get a tool made as it is a one off
  16. #13
    Mar 2016
    AUSTRALIA
    6
    Drill 18mm hole first .then use a 16mm end mill with a 2mm rad . Sorry not 12
  17. #14
    Sep 2010
    Victoria Australia
    3,845
    1532
    Quote Originally Posted by tyson333 View Post
    Hello tyson,
    Following is a Basic Macro program to step mill the taper. Because its a "one off", I've pre-calculated the tool Z Start and Radius for the initial circle at Z Zero, rather than create the Macro Code to do so. This is based on the Bull Nosed End Mill with 2mm corner rads you specified. Any Bull Nose Cutter up to just under 17mm diameter can be used with the code as is; Tool Radius Comp has been included. I've also pre-calculated the Taper per Millimeter and included that as Hard Code in the program.
    This is a Bare Bones example without any Error Trapping. You could develop the Macro more so that the Corner Radius of the cutter could be specified and have the Macro calculate the Z Start and Finish Levels.
    You can edit the Z Increment Variable Value (#1) to modify the surface finish of the taper; the smaller the Z Increments, the finer the Surface Finish.
    I have carried out a rough test and I can't see any obvious issues. However, as the Fanuc User Macro Application carries out calculations in Binary, there may be inherent errors in the calculation that may not have the DO LOOP end as expected. The program did perform as expected in all the tests I did using a multitude of different Z Increments.
    The only issue will be that the calculated Final Z Value my be ever so slightly different to the #5 = -39.765 '(Z FINISH COORDINATE) used in the WHILE Statement and therefore, never tests Equal; only Less, or Greater Than. The result of this is that one extra Z Increment and cut cycle will be performed. There are "work arounds" for this:
    1. After #3 = #3 + #1 (Z CUT LEVEL) is executed, perform a comparison to the Final Z (#5) and if #3 < #5, set #3 to the value of #5 in the following manner:
    IF[#3 < #5] THEN #3=#5
    However, its not quite as simple as just setting the Z Value (#3) to that of the required Z Final Value; you also need to calculate the Radius for that particular Level.
    2. Subtract #3 from #5 and compare the result to an acceptable, small tolerance; 0.0001 for example. If the Result is <= to the tolerance, then #3 is deemed to be equal to #5 in the following manner and an Exit from the DO LOOP executed.
    IF [[ABS[#5]]-[ABS[#3]] LE 0.0001] GOTO10
    CODE
    END1
    N10
    Example Macro Starts Here
    (INITIALISE VARIABLES STARTS HERE)
    #1 = -0.1 '(Z INCREMENT)
    #2 = [0.11842 * #1] '(RADIAL DECREMENT)
    #3 = -1.765 '(TRUE Z START COORDINATE)
    #4 = 14.014 '(START COORDINATE RADIUS)
    #3 = #3 - #1 '(INITIAL Z START COORDINATE)
    #4 = #4 - #2 '(RADIUS START VALUE)
    G90 G00 X0.000 Y0.000
    G00 Z10.0
    G01 Z1.0 F1000
    G01 Z#3 F500
    (TOP CIRCLE STARTS HERE)
    WHILE [#3 GE #5] DO1
    #4 = #4 + #2 (CUT CIRCLE RADIUS)
    G90 G01 Z#3 F500
    G01 X5.514 Y0.000
    G01 X[#4 - 8.5] Y0.000 (FEED TO CENTRE OF LEAD IN ARC)
    G41 G01 X[#4 - 8.5] Y-8.500 D22 (APPLY TRC)
    G03 X#4 Y0.000 I0.000 J8.500 (LEAD INTO CUT CIRCLE)
    G03 X#4 Y0.000 I-#4 J0.000 (CUT CIRCLE)
    G03 X[#4 - 8.5] Y8.500 I-8.500 J0.000 (LEADS OUT OF CUT CIRCLE)
    G40 G01 X[#4 - 8.5] Y0.000
    G91 G00 X-1.0
    END1
    G01 X0.000 Y0.000
    G00 Z10.0
    Following is the Graphic Back-plot resulting from the above Macro Program.
    Regards,
    Bill
  18. #15
    Mar 2016
    AUSTRALIA
    6
    That is awesome .thankyou for your time .as i am just learning macros.
  19. #16
    Mar 2016
    AUSTRALIA
    6
    Had to take out that last g03 lead out of circle as the cutter was stepping in to the taper half way down. Now it works fine perfect finish running at 3300rpm f700 .perfect finish and not a single tool mark.
  20. Likes Ox, yardbird liked this post
  21. #17
    Sep 2010
    Victoria Australia
    3,845
    1532
    Hello tyson,
    I'm not sure what you mean. Are you saying the Lead Out all the way down, or just at the last Z level? I can't see how that would, or could cause an issue. Following is the generated code for the last Z Level:
    G41 G01 X1.014 Y-8.500 D22
    G03 X9.514 Y0.000 I0.000 J8.500
    G03 X9.514Y0.000 I-9.514 J0.000
    G03 X1.014 Y8.500 I-8.500 J0.000
    G40 G01 X1.014 Y0.000
    As can be seen, the End of the Lead Out is a mirror image of the Start of the Lead In. Accordingly, if the Lead Out was an issue, so would be the move to the Start of the Lead In. The following picture is the Top View of the generated Tool Path. The Radius of the Lead Out Arc is 1.014mm less than the Cut Circle at the last Z Level and therefore, the centre of the Lead In, Lead Out arcs are on the plus side of the tapered bore's centre line.
    Regards,
    Bill
  22. #18
    Jun 2015
    Minnesota
    507
    9
    179
    SaaaaaaaaWHOOOOOSH!!!
    That's the sound of Bills' post #14 flying right over my head.
    One of these days I gots to learn Macro B programming.
    Dave
  23. #19
    Nov 2013
    Eastern Massachusetts, USA
    5,306
    5092
    5118
    A company I worked for did exactly that in castings before thread milling a large tapered pipe thread. They used a tapered end mill. When milling the thread they started at the bottom and spiraled out using circular interpolation with a ramp factor added. I do not know the details of the programming because I was in engineering, not the shop.
  24. #20
    Mar 2016
    AUSTRALIA
    6
    Hey bill
    It was only starting to cut into the wall about a halfway down on approach of the first lead in so like i said once we took that last lead out of the arc it seem to fix it as well as the g01 x5.514 y0...i was guessing the small diameter to taper to as i was at home at the time apon posting this discussion acual taper was 28mm to 23.000.so i chanched the value #2=.0656167 .
