Darkstriker69
- May 3, 2021
I purchased a used Clausing FV-1 3 axis dynapath CNC mill and unfortunately I think the X axis was crashed hard because the limit switch was broken and the X axis ball screw has a huge amount of play. I would like to remove the ball screw and nut to see exactly what the problem is but I can not figure out how to remove the nut from the yolk.
I removed the two screws that attach the ball screw nut to the yolk and expected them to pull apart but that does not seem to be the case because I can not get the two to separate.
Any insight as to how this comes apart?
