Cleaning CNC Machined parts
Gert86
Nov 13, 2021
Hi,
I was wondering as my husband who is a machinist (I’ve only been an operator) wants to run our coolant covered parts in the dishwasher if anyone else has done this.
Will it leave a film on the dishes, we have a kiddo I don’t want him ingesting coolant.
Will it over time damage the dishwasher?
Slap him he knows better then that. Tell him a man is supposed to watch out for women and children
Don
Hi,
Simply go shopping by the side of the road.
Not a week goes by I don't see one looking like new at the curb.
Have him install it in the shop for just those parts.
Would he drink the coolant? Of course not.
Tell him to install a dishwasher for parts in the shop, or better yet an aqueous parts washer. Leave the kitchen for non-industrial matters.
Use Dawn dish soap mixed with water for coolant. Or Ivory liquid. Then mix some in his morning coffee. He will get the idea. It WILL get him moving quickly.
I think thats a pretty clever idea.
Id probably get a separate dishwasher but in all honesty id say the amount of coolant contaminating your dishwasher is probably WAY less then what we breath in every day. Especially if you rinse parts before hand.
I don't see why not, it all gets washed away and goes down the drain. I'm sure it's been done before, especially if it's water soluble coolant.
Considering dishwasher detergent is the closest thing to lab cleaner we can get I don't think it would make any difference to your dishes. Residential dishwashers don't do a good job of rinsing the detergent off and if you use a spot rinse then I doubt any coolant residue will be any worse.
Depends on your coolant. I use Hangsterfer's 5080, which is basically food grade. I've splashed it in my eye and it didn't even sting. That said, there are more efficient ways to clean parts. I use an ultrasonic cleaner with 99% IPA (isopropyl alcohol, not India Pale Ale). Five minutes does it.
Related question, considering waste coolant is supposed to be collected and disposed of properly to avoid it contaminating the water stream is just washing it down the drain through something like a dish washer safe or even legal? Seems like a technical minefield if you start thinking about it because even washing your hands after getting coolant on them means washing some down a regular drain.
As above I've started using an ultrasonic cleaner to clean parts before I send them for anodising, mainly to get any gunk out of threads and it works a treat, in my case 30 seconds gets the job done. Plastic parts go into warm water to remove excess coolant too and the weak coolant water gets tipped into the machine after.
A large ultrasonic tank will be better then a dish washer as mentioned above. Use something like an industrial floor detergent and dilute in water, you won’t need much, and it will clean in small gaps and holes much easier!
And you will be better off getting a lower frequency sonics tank then higher frequency, trust me!
Agree with the above posters in that heated Ultrasonic cleaners are the way to go. A dual frequency unit is best. Use the lower frequency for softer metals and higher frequency for steels, etc. Using the higher frequency with softer metals (i.e. aluminum) will etch the surface leaving little white "blooms" all over the part(s).
My suggestion would be a dishwasher off of Craig's or similar, set up in the shop.
To answer your question, it is unlikely that any coolant residue would affect you, particularly if the parts have been rinsed or air blasted before going in.
But I've seen perfectly functional dishwashers left curbside because someone was remodeling or didn't like the fascia.
These other guys must have worshers that re-use the same water over and over?
I Shirley don't see any reason that it would be in any way harmfull to you or machine.
Think Snow Eh!
Ox
Been using a dishwasher to clean parts for 30 years.
If you had a CAT scan in the 80s-90s the boards in the machine most likely went through a dishwasher. I seen it meself
Yeah, free roadside dishwashers are better than the house one.
If only to keep the wife happy
It does not work very great for part cleaning,
Thought it might be a good way and tried all sorts of stuff due to the costs incurred with finish part washing. Did not work well.
I tried and tired as this step well over 5 cents per part in volume.
I would never put dinner dishes in such.
I wanted this to work out so badly. Chased it to extremes.
Bob
I've run 10's of 1,000's of parts through a regular household dishwasher. 6061, 7075, and 3xx stainless. No detergent, just hot water rinse cycle or 2. Everything comes out squeaky clean, as long as blind holes are oriented down.
Using Blaser water-soluble coolant.
Maybe I'm just lucky. Works a treat for me.
Regards.
Mike.
