abbeyroad1124
- Feb 8, 2021
I bought a set of five ER32 collet chucks and a collet set from cme-tools.com.
Their claim is <= 0.0002" run out.
I fitted a different size carbide mill in each and found that they all had high run-out (0.0007" etc.)
So for each chuck, I rotated the collet in the chuck 90° and retightened, and retested, and rotated again, and I seemed to be able to get <0.0001" run-out for each. In this way the run-out of the collet and chuck cancel each other when they are oriented just right. But only if you spend time iterating.
IS THIS NORMAL??
CME-Tools customer support says "we sell thousands of these and don't hear such a complaint".
In fact I notice most machinists don't normally test the run-out of tools at all, so perhaps when cme-tools customer support says this, it might be true.
I measured the run-out of a different brand in the bore of the ER32 taper, and did the same with the cme-tools bore.
CME-Tools is off 0.0005". The other brand was <0.0001" and also <0.0001" with the tool turned 180° in the spindle -- so it isn't my spindle.
Everyone seems to recommend Maritool but these seem really expensive. What about tpactool? Anyone use them?
IS THIS NORMAL??
