Captdave
Titanium
- Sep 24, 2006
- Atlanta, GA
Have had this machine now for a little over 3 years and been a great saw and it runs 8 hours almost every day. I was never really pleased with the blade life cutting 6061 rod, most 4-1/4" to 6" using Lennox classic pro 3-4 pitch blades. We use Lennox online blade speed calculator to set the speeds and feeds based on their recommendations but we still only get 100-120 hrs before the blade breaks at the weld. We have tried several different vendors but the results are pretty consistent. We did get one that went 400hrs once
I maintain the machines myself and keep the blade brush replaced as needed. 6 months ago I replaced all the blade guide bearings but not the carbide guides as they showed very little wear.
So my thought now is maybe coolant. We use the drained coolant for all the hoppers to keep the band saw full and add a little mix to keep it ~10%. Do you guys run your coolant at a higher mix?
