Rider
- May 3, 2004
- Wasaga Beach, Ontario, Canada
Hi all, I am new to this and have been thinking which machine would be the best to use in making automotive T6 aluminum wheels.
The two machines I have seen was that of a Viper 950 Vertical Machining Center CNC and that of a Haas VF-5 20 HP Vertical Machining Center. The first question I would have to ask which machine should be best to use if either machine or should a Lathe CNC.
The next question would be if I were to make a 2 piece wheel and weld the centre billet to the main outer rim, which welder would be of good choice.
