CNC changed itself to German
Results 1 to 16 of 16
    Aug 2016
    Nebraska
    9
    Default CNC changed itself to German
    Hello. SIEMENS 2100 controller switched itself to Something that looks like German over the weekend. It also will go blank after about 20 minutes. I had no battery alarm. Still even if it went bad why would it switch language lol. I cant read it to fix anything . Tech support wants $300 to talk to me because it's a older system. Is it more serious. A board go bad. I could use a good source for help if it's more serious. Someone that can come look at it. In Paxton Nebraska. Thanks for the help.
    Jul 2006
    Hillsboro, New Hampshire
    7,772
    1816
    5467
    Und you vill like it dat vay!
    Sep 2002
    People's Republic
    3,360
    281
    2200
    Not a Siemens guy, but German would be default language I would think, so maybe it has lost power even without alarm. I guess I would replace battery and then check power supply voltages.
  4. Likes Scottl liked this post
    Nov 2012
    Wisconsin
    2,106
    3456
    2645
    Are you sure it did it on its own?
    Experienced a Heidenhain control doing a similar thing. Except I eventually found out it was a bored 3rd shift operator playing with magic that he didnt understand lol
    He was messing around in the parameters.
    Nov 2013
    Utah
    4,644
    1223
    2604
    The other thing you could dooo....
  7. Likes gustafson, digger doug liked this post
  8. #6
    Aug 2010
    Medina OH
    1,977
    180
    911
  9. Likes M.B. Naegle, gkoenig, Leadfootin, rcoope liked this post
  10. #7
    Aug 2016
    Nebraska
    9
    Lol yeah. I don't think anyone worked the weekend. Might have to use a translator to get it back to English.
  11. #8
    Mar 2006
    PHILIPPINES
    2,498
    573
    816
    A couple of ways you can go about this but first you could just try to swap to English from command prompt.
    1. Firstly press the Windows logo key and R on the keyboard, you will then open the Run prompt on your computer screen. Type cmd, then press OK, you will open the Command Line on your Windows PC.
    2. Input and execute follow command in the CMD prompt:
      chcp 437. This is the code for English
    The second is a bit dangerous because it opens the master service option so you can get into the windows system itself. You would need your service manual to follow the key steps since they are not in English. When the system boots Click on (Bedienung) German for service. The master password is "worldclass", This will allow you to make changes within windows NT itself. Use your phone or another PC and follow the clicks on a YouTube video about changing languages in windows. DON'T go into "folders". The A-2100 Keeps a backup of the MAI in (D) drive and if you click it your system will reboot to factory fresh and you will lose everything.
    After you reset the language to English check you screen timeout setting to see if this is what is shutting you down after 20 minutes. I suspect your graphics card is probably about to kill over so not sure if the system timeout will do any good. Once you have it back to normal click service again from the CNC screen and set password to "operator". The A-2100 is by far my most favorite system but it's super delicate. If you're unsure of what it does,,,,Don't touch it.
    Here's one more video I found that at the 1:23 mark shows the keyboard and display can be changed inside the MAI. I'm not sure if it changes the windows language or just the system UI.
    YouTube
    Bedienung
  12. Likes Milland, digger doug liked this post
  13. #9
    Apr 2018
    UNITED KINGDOM
    2,607
    1218
    Quote Originally Posted by g-coder05 View Post
    Is the A-2100 also an Acramatic control ?
  14. #10
    Mar 2006
    PHILIPPINES
    2,498
    573
    816
    Quote Originally Posted by EmanuelGoldstein View Post
    It started out As Vickers Acramatic then became Siemens Acramatic.
  15. #11
    Oct 2005
    15,739
    Is it trying to "phone home" ?
  16. #12
    Nov 2013
    Eastern Massachusetts, USA
    4,425
    4588
    4597
    Take a picture of the screen and then go to a computer and type the words one sentence or so at a time into an online German to English translator. Somewhat tedious but free instead of $300.
  17. #13
    Oct 2014
    CANADA
    Ontario
    1,217
    690
    930
    One thing that might be really useful in this situation is the 'Google translate' app on your phone. The new versions of that app have a 'live text translation' mode where you point your phone camera at something and then it shows the picture of it on the screen, but with all the text translated to english, and it does this in real-time.
    This will at least give you a way to potentially find the parameter and change it back!
    I have used the same feature pointed at my computer screen while browsing some obscure AliExpress listings that had only chinese writing on the boxes of the the products they were displaying and it worked well!
  18. #14
    Jun 2019
    323
    98
    285
    Maybe it was made in Poland. Better watch it if he has any French machinery next.
  19. Likes digger doug liked this post
  20. #15
    Aug 2016
    Nebraska
    9
    Yes.. no keyboard
  21. #16
    Apr 2018
    UNITED KINGDOM
    2,607
    1218
    To Cincinnati ? It'll need a time machine. Acramatic is a Cincinnati control. Cool that they are still alive.
