Hello everyone,
I had a minor crash from which it resulted a big problem.
The sub-spindle collided with a tool post and now it is not centered with the main-spindle.
I've checked with 2 calibrated bars of 4 mm diameter and set them apart by 0.25 mm but I managed to insert a 0.6 mm plate between the bars, so they are approximately 0.35 mm apart.
Is there any way I can reset the machine to its factory reference points? It's hard to imagine the sub-spindle head shifted from its place from the collision, or did it ?!
I have attached two pictures showing the unalignment between the sub-spindle and backwork toolpost.
The machine is a Tornos Swiss Gt13 with Fanuc 32i
Is this an mechanical problem or can it be solved by reseting something.
