CNC Drilling Question
2quix
Sep 5, 2019
So im currently drilling alot of deep holes in our mould. Ive pre-drilled all the holes 3" deep with a shorter drill before going in with a longer drill to reach the required depth. My question is, is there a way to get it to start 2.9" down inside the holes, but come back up past the top of the piece for chip clearance. Right now we have it cutting 3" of air before it even starts to cut material. And add on top of that if the drill dulls having to sharpen it and start that hole all over again.
Thanks.
are you using CAM ?
With my CAM it is easy,when you change drill bit to longer size change top of job to the depth your shorter drill got to.Just be sure to add that amount to your rapid plane.Give us a little more to go on and someone can tell you for your specifics
are you using CAM ?
Emphasis on the part that will save you from a shiny new 2 piece drill.
Thanks.
In the time it took to drill that extra 3" of air on that first hole you could've hand coded the rest of the holes and had them ready to go by time that hole was done.
Or went back to the cam and programmed it correctly. What is your point?
As others state, need a little more info. Yes there is a way to do that, but we need to know what cam, if any, you are using, or if you are fingercamming it or what. Plus machine and control would be helpful.
Thanks.
i believe its usually use G98 or G99 to set initial Z
G0 G98 Z2.0
G83 X0. Y0. Z-6.0 R-2.9 Q0.5 F3.
X2.0
G80
....so initial Z set for Z2.0 it rapids to R-2.9 down into hole and peck drills to Z-6.0 when there it rapids to initial Z2.0 before going to next hole
with G99 it goes to R between holes so R must be above hole only when it sees G80 (end of drill cycle) does it go up to initial Z with G99
obviously you would have to test it on your cnc above or clear of part to confirm ok then put tool comp back to normal to run program
if using short peck G73 you can
G0 G98 Z2.0
G73 X0. Y0. Z-5. R-2.9 Q0.5 F3.
G73 X0. Y0. Z-6. R-4.9 Q0.5 F3.
G80
it rapids to R-2.9 into hole from Z2.0 short peck drills to Z-5.
pulls out rapids to Z2.0 then rapids to R-4.9 to drill to Z-6.0
thus a short peck that pulls all the way out once then goes back in to resume drilling
obviously test it with adjusted tool comp well clear of part to confirm working as expected before putting tool comp back to normal and running program
It's still only going to retract to the R plane between pecks. I think the OP wants to start in the hole and retract above the part for each peck.
Haas does it but I don't know about any other controls.
Point is I hate doing this kind of shit in cam. Obviously don't know the extent of what the OP is dealing with, but assuming deep hole drilling with spindle speed variations at certain depths going into and coming out of the hole, I'm hand coding this sans canned cycle, plugging it into a plotter and watching like a hawk before it goes into the machine.
<<shrug>> Different strokes and all. I am not sure what the OP has at his disposal, or control or whatever so I guess it is a moot point. We do 99% of any reworks to program in cam so it is saved for next time we run the parts. But if it is a one off I could certainly see making some hand edits at the control and just gitin' er done. :cool:
I only do it that way because I haven't learned the custom drill cycles in Mastercam and I was ashamed to admit it.
But yeah, the times I've done it have been for anywhere between 1 and 5 holes. Any more than that and I'd cam it.
The best way IMO is to add a custom deep-hole drilling cycle to your post processor. The tool mfg. often wants you to spin slowly while feeding in, then turn on thru-coolant and spin up, then feed in at a slow rate for a bit, then get to full speed, then at the bottom turn off coolant, spin slowly, and feed out. Once you set this up in your post processor it becomes as easy as programming any other hole.
I think something like this would work...the G99 in the G83 cycle would bring it up to Z.1 between pecks but the G01Z-2.9 line right before would move the drill down in the hole at a high feed rate before you start pecking. The P word in the M98 line calls the sub program that begins with the N number equal to the P number (100 in this case) and then zips back to the main program after the M99 line in the sub. So all you have to do is keep repositioning in X and Y and calling up the sub to do the drilling. Good luck!
G0X0.Y0.;
M98P100;
X2.0;
M98P100;
X4.0;
M98P100;
N100;
G01Z-2.9F100;
G83Z-6.F16.Q.2R.1G99;
G80;
G0Z.1; (I think the G99 in the G83 line would put the tool here anyways?)
M99;
"Custom drilling cycle"??? This is standard FANUC folks!!!
G0 Z5
G98 G81 R-2.5 Z-10
Done!
G98 and G99 and G83 and G73 can be used many ways. point is G98 at end on drilling EACH hole it goes back to initial Z and not to R like it does with G99
useful if you want R to be rapid down into the already drilled hole and drill to go to initial Z out of hole for moving to next hole location
usually easier to write (short peck WITH a long peck)
G17
G0 G43 H1 Z4.0
G98 Z2.0
G73 X0. Y0. Z-5. R-4.0 Q0.5 F3.
G73 X0. Y0. Z-6. R-4.9 Q0.5 F3.0
G80
the line with G98 sets initial Z and if on a line by itself its easier to read. since i have used it many hundreds (if not thousands) of times i prefer it written so easier to read. like i already said using a short peck with a long peck is useful too as when over 6" deep on horizontal holes external coolant does not normally reach drill tip and a pull out of hole to clear flutes of chips and wash it with coolant can help considerably. sometimes if rapid too fast the chips dont wash off flutes and fast rapid back into hole can compress chips still in hole and break a long drill bit
....and really long drill bits often you long peck but keep drill tip a inch or 2 in the hole as once out of hole the drill tip will whip around considerably. sometimes have to enter and leave hole at slower rpm and change to higher rpm when safely in the hole
obviously on a 5 axis machine you need to state G17 G18 G19 or the drilling plane or axis. not all machines only drill using Z some drill in X or Y too. same with tool comp G43 and G44, you can drill toward negative or toward positive direction. when complicated it helps to run cycle well clear of the hole drilling air to see if everything working as expected
remember you can program a hole at same XY location but with different Z and R. that obviously can be done in CAM too. same XY but program it like drilling 3 different holes
short peck is also useful if long drill if feed too fast the tip not drilling into as fast as tool holder is moving and long drill starts bending. the short pull back on short peck helps let the long drill straighten out. obviously if 2 holes at 90 degrees are suppose to meet 6" deep into part its not good if the holes are curved enough the holes do not connect. got to watch the feed rate with longer drills even if they do not break a curved hole can still be a big problem
G0 Z5
G98 G81 R-2.5 Z-10
Done!
Right, but I think OP wants to peck and retract above the part for chip clearance. Wait...does G98G83.... retract to initial Z point or R-plane while pecking for chip clearing???? I thought the individual pecks always back off to R plane and G98/99 only affect where it retracts to after reaching final z depth??
it retracts to the R plane, R stands for Retract. When you post it longhand, you can make it do whatever you want, and it will run on any machine, any control.
