CNC lathe collet
Likes Likes:  0
Results 1 to 3 of 3
    Jan 2018
    EGYPT
    Default CNC lathe collet
    Hi there,
    I have a CNC lathe collet for 20 mm bar and I want to change the bar dimension to 25 mm
    Is it save to enlarge the collet to the required diameter by turning or wire cut machining, or it is better to make another one?
    Aug 2013
    Chicago, IL
    1,005
    707
    388
    What style collet? (I.e. ER32...)
    Virginia
    30,487
    7561
    9523
    Quote Originally Posted by esamali View Post
    Hi there,
    Most folk just BUY the size(s) needed from other folk who have the making of collets as their line of business.
    Either size you cite, any of a dozen or so collet "systems", the collet itself is small enough and light enough for parcel or courier service from any source on-planet to any destination not proscribed at source.
    Page Two:
    Not all collet systems that can accomodate 20 mm have a maximum size that accomodates 25 mm. If that is your case? You'd have to upgrade the holder for larger range, not just the one collet.
