Jrill
- Feb 11, 2013
- Northeast USA
Last time I sent out end mills to be resharpened it didn't go so well. Want to make sure I'm doing my part this time, so I have a few questions, and in addition to that I'd appreciate a general walkthrough of what you guys do when you send out mills to be reground.
1. If I send out severely chipped end mills to be sharpened, what will they likely look like when they're returned? Will they be broken just sharp on the periphery? Will they grind 0.1-0.2 off the LOC to create a new end?
2. When I send out end mills to be resharpened, do I need to specify what angles I need? (I sent out some aluminum specific 3FLs to a local regrind place a while ago and they came back and chattered like there was no tomorrow, and I'm assuming they were reground with generic angles instead of the factory angles).
3. Is it generally a good idea to send them back to the factory I got them from? Will they probably recognize the list/geometry and regrind them appropriately?
So basically I want some advice on what I need to do to get them back retaining their material-specific/factory angles as much as possible (does sending them to the factory ensure that?), what do I need to specify and request when I send them out, and I'm curious if I can send out severely chipped end mills and have them returned being functional (just shorter or something).
