You are not going to mill sintered alumina. That's aluminum oxide, or sapphire, and is a common high-grade abrasive. You will need to grind it with diamond abrasives (NOT diamond coated cutting tools) and lots of water or cutting fluid. It will be a very slow and difficult process. The machine will need to be very precise and rigid to produce acceptable results.
