The idea was that 1.000 +0, -.01 is pretty much the same as 0.995 +/- .005
I tend to agree with the comments about shooting for half allowance and go from there, then working your way as close to nominal as you dare, but in a CAD/CAM environment, you would never start reworking CAD drawings so that the lines in the drawing are different then nominal as I'm sure they're drawn originally. What a nightmare that would be. The tool path coordinates are generated directly off the drawing, so nominal is what you're working with. If you're creating and using an offset tool path, sure, include the extra five thou in your settings. But as I've said before, I think all finish passes should be done with comp. I would program to the nominal feature line(s) and be prepared right from the start to skinny up my comps on periphery work and just the opposite on bores. That is, in this minus only tolerance example.
It’s more of a general question. It could apply to a hole size or hole location, or length of part
Mill ?
Lathe ?
Chainsaw ?
Should a CNC programmer program to the print dimension or to the nominal number. Example, if you have a dimension of 1.000 +.000/-.010. Should he program the part to 1.000 or .995. Thanks for your input.
Although not very fancy simply programing the tool oversize will easily put you in the middle of tolerance without modifying any drawings. Or stock to leave or whatever other fancy feature your CAM program has.
The reason I ask is my programmer always does the print dimension and a lot of times the first part is bad. And I tell him to program it to the nominal dimension so your not on the edge of making a scrap part. So I wanted to see if it was standard practice to program to nominal. And yes I am an inspector ��
Everywhere I've worked we would program to 0.995. The idea was that 1.000 +0, -.01 is pretty much the same as 0.995 +/- .005 (I know, I know.. it's not but effectively it is). You have more chance of getting more good parts off the machine if you (correctly, IMO) assume you can equally likely be over as under on any given dimension.
If you haven't got that figured out I wonder what you're programming.
Smells trollish to me.
Notice
