eastbaysteve
- Jan 4, 2021
Greetings! This is my first post so I will start by saying hi!
My first job back in the day when I was 18 was running an old retro-fitted excellon 3 head router (as in, it used to run those tapes with the holes punched in it, lol). Back then I wrote all the G-code by hand. Simpler times, haha.
I am looking to plan out some new shop space and buy some gear so I figured I would reach out and listen to those who know far more than myself for some advice.
I need to cut Fatigue-Resistant 301 Stainless Steel that is 0.01" thick (McMaster-Carr). I need it to keep as much of its hardened/tempered state as possible. This stock will be cut into shapes (probably do this in Fusion 360), nothing too complex. 2" x 2" with rounded corners, maybe a notch or two and a few holes.
I know some people who have cut this type of stock with really sharp metal cutting scissors or shears since it is so thin, but with the precision I would like to get I was really hoping I could route these out with a CNC router.
Easy peasy? or am I dreaming? (and if I am, how would you approach this?)
Any advise/thoughts would be much appreciated.
Edit: This is technically for work so my budget is flexible when it comes to gear. A good CNC router was already on my radar for other uses, however, trying to keep things as simple as logical.
