MwTech Inc
Titanium
- Feb 6, 2005
- Fishersville VA
OK. very adept at manual machining from a Bridgeport up to my #4 vertical.
But with a VCM on the way, watching hundreds of videos it seems that everyone uses a 1/2 end mill to cut everything taking a jillion passes.....
It is actually faster/better to make a jillion passes rather than using a large cutter ?
Now, if I have a good size bit of material to remove, I use a 1" or larger and just chew right thru....
maybe I will need to "re-learn" cutting with a VCM???
VCM i'm getting has 7 hp spindle
Remember i'm not competing in the CNC parts market so cycle time does not really matter to me
