Gerrythewelshman
Cast Iron
- Oct 1, 2006
- Ireland
Hi All,
Today I thread-milled a 36mm (1.417")thread 4mm (0.156")pitch with a 27.5 (1.082")cutter dia.
with compensation in the programme .I used an I. and K. for the radius output. Not a problem.
Normally when programming using cutter comp. If you travel less distance than the radius of the cutter it normally faults out. Is this because I am using a R. (Radius output)?
Am I explaining this ok
