SeymourDumore
- Aug 2, 2005
- CT
Guys, is there a chart showing what are the standard compression fitting thread sizes?
I have a personal project with some solar-thermal panels made by Schuco, and the numbnutses made the connection as Krautized as it can be.
They've used a 12mm copper pipe for the guts, and made the interface to the outside world by putting a half round bead on the tube only about a 1/4" from the end.
The bead serves two functions.
It is the sealing surface similar to the way copper/brass compression fittings seal, AND it constrains a flange nut which is what's normally used to attach it to the piping system.
Anyhow, Schuco USA has completely terminated all of it's operation in the US, and as such there are no mating fittings to be had.
But!
I've found a short document stating that the connection types are "compression" fittings.
Problem: These are larger than 5/8, which is the max to which HD or Lowes go, therefore I cannot just get something off the shelf.
But!!!
I do have a bunch of machines that CAN make a custom fitting, as long as I know what they should be.
Is there a difference between metric and imperial?
Thank You
But!
But!!!
Thank You
