Conquest 42 threading cycles
Results 1 to 15 of 15
    Dec 2018
    Florida
    7
    Default Conquest 42 threading cycles
    Hello everyone
    I have a Hardinge Conquest 42 that is set to work in inches/minute, and the threading cycles are not working (G32, G76)
    I have tried G32 Z-0.15 F0.0313 for 10-32 thread but the machine does not move
    I have also tried S960 M3 and G32 G98 Z-0.15 F30 but it will not move
    What command do I need to have the threading cycles work?
    Thank you
    Oct 2010
    Dewees Texas
    2,255
    26
    593
    I have a GT with the 18T control and on it the G76 threading cycle need to separate G76 lines on with parameters for the thread and another with the usual info. I do not single point that often and have to spend some time studying each time I do an new single point thread.
    Looked at your post again threading in inches per minute with a G98 in the line? Is that even possible? Why not inches per rev. No spindle encoder?
  3. Likes cameraman liked this post
    Dec 2018
    Florida
    7
    Quote Originally Posted by FredC View Post
    Coul you pleasr provide a sample of theading cycle for a 10-32
    Oct 2010
    Dewees Texas
    2,255
    26
    593
    The only 10/32 or 5mm thread we have done on the GT was behind a shoulder with an thread mill.
    Here is a sample of what our machine looks for:
    (7/16 FINE THREAD))
    T26X.49834Z.25
    G76P010000Q00100R.0
    G76X.3749Z-.695P03067Q00970F.05
    G01
    The manual has a bunch of formulas for doing the Parameter line. We do so few that I have to spend some time working it out. I do not think this will help the OP, though.
    Aug 2002
    West Unity, Ohio
    24,870
    5091
    7672
    If 2-line:
    G76 P010160 Q00100 R00100
    G76 X.147 Z-.15 P01970 Q00980 F.0312
    0 = If it is an "SP" model machine
    All depends on what year and what control that you have.
    I kan't hep with 1-line programming.
    Think Snow Eh!
    Ox
    Dec 2018
    Florida
    7
    Hello
    I just tried the codes then the machine moved the entry in X but then it stops in Z
    The machine doesn't move in Z with G32 or G76
    Aug 2002
    West Unity, Ohio
    24,870
    5091
    7672
    So again - what year and what control?
    0T or 18T are the likely choices - depending on the year.
    Maybe your machine takes a "1 line" threading code?
    Someone else would hafta hep you with that.
    Think Snow Eh!
    Ox
  9. Likes cameraman liked this post
  10. #8
    Dec 2018
    Florida
    7
    Tha nachine has control O-T,
    Year: 2002
  11. #9
    Mar 2003
    Upstate New York USA
    281
    43
    will the machine feed in either IPR with the spindle running? Try the following in either MDI or AUTO modes this will determine if you have a spindle encoder feedback problem or not. I am guessing the spindle encoder is faulty as the G32 line you from your first post should have moved the Z axis
    M3S500G97
    G1G99W-.2F.01
    Tom
  12. Likes FaustoShuguli liked this post
  13. #10
    Aug 2002
    West Unity, Ohio
    24,870
    5091
    7672
    It heps when you give us all the pertinent info.
    So then it is a Conquest T-42 with an 0i-T control maybe?
    If so - it should take the 2-line program.
    Does the Z axis work otherwise?
    Will it feed in G99?
    I'm guessin' that you somehow lost your spindle encoder.
    I don't know if that's the same as the one used for G99 or not?
    edit:
    That putz Tom snuck in ahead of me....
    Think Snow Eh!
    Ox
  14. #11
    Dec 2018
    Florida
    7
    Quote Originally Posted by Tom View Post
    M3S500G97
    G1G99W-.2F.01
    Tom
    Hi,
    I have tried G1G99W-.2F.01, the machine does not move.
    Is this a spindle encoder problem??
  15. #12
    Dec 2018
    Florida
    7
    Hi,
    The machine is a conquest 42 with one spindle, control O-T, (one line programming)
    the machine has been configured in inch/min (ACT.F)
  16. #13
    Aug 2002
    West Unity, Ohio
    24,870
    5091
    7672
    Then it's not a 2002.
    I don't even think that they were still building "T"-42's in 2002, but maybe...
    Think Snow Eh!
    Ox
  17. #14
    Dec 2018
    Florida
    7
    You right,
    There is a mistake in the machine year, the machine is 1990
    FS2000
  18. #15
    Mar 2003
    281
    43
    If the machine will not feed in G1G99 mode then you have a spindle encoder issue, could be the encoder, the wiring or possibly a belt - I believe that there is a timing belt from the spindle to the encoder on those. The same spindle encoder system is used for both IPR (G99) and all threading commands G32, G92, G76.
    On a side note unless someone changed the machine to the Fanuc System Type 10/11 then the G76 threading cycle is a 2 line callout (this was the standard setting on machines shipped), the type 10/11 format is a single line call out and was an option at the time
    Tom
