03-01-2021, 09:10 PM #21
DrHook liked this post
03-01-2021, 10:11 PM #22
Little off topic here, but he reminds of the the operator who used to run the machine next me at my last job. He asked me one day if he could use MY washdown hose to clean HIS machine because mine had more pressure LOL. I still kick my self for not letting him go ahead with it...
wheelieking71 liked this post
03-01-2021, 11:33 PM #23
Separate sump tank is also an option. Hell, I think it was Tonytn36 with some pictures on their machines a long while ago running like that.
I mean, you're a car guy... you can't tell me you don't want a dry sump lube upgrade on your R650!
03-01-2021, 11:43 PM #24
I'd go the stock tank route, with a transfer pump to fill it and an overflow back into the main tank incase the float switch fails. As much as I hate Chipblaster, I haven't seen one of their tanks overflow and they've used that setup for a long time.
03-02-2021, 09:00 AM #25
With the minimal difference in head between the main and an extension tank you're not likely to get the flow you need between two tanks. You'd need a really big transfer line and that gets difficult. Adding pumps adds complexity.
The simplest and most likely to work option is to add to the tank. You can cut some gaping holes into the existing tank prior to welding the extension onto it to insure the flow. What I've done in the past with similar projects is to get a sheet metal shop to shear and bend up some material ahead- just a simple angle or two with one leg the depth of the tank and the other leg the width of your extension. Even get them to put a hem on the top edge. With this approach you'll have a lot less welding.
03-02-2021, 09:23 AM #26
I have a machine with 2 coolant tanks, one on either side of the machine. I set it up with a 1.5" hose between, with cam lock connectors for irrigation equipment sourced from the local farm store. Has been fine, but the main tank has both pumps and catches most of the return flow, the second tank does not get much of the return coolant so there's not a lot of flow through the hose. Approx 100 gallons total.
03-02-2021, 09:44 AM #27
03-02-2021, 10:53 AM #28
I don't have a Mayfran, but I've learned that playing with the timing of the chip flush system can make a difference. When it comes on, how often, and for how long. You likely already played with all that, but once in a while I forget the obvious.
Another thing I played with, which end mill, rougher, etc to get chips to cooperate and work best, get flushed easiest, not cause the tank to overflow etc. You likely thought of that too, but I had a couple of learning experiences along the path involving tanks overflowing.
Good luck!
03-02-2021, 11:21 AM #29
I would get a stock tank, if 55 gallons is too small, as my main tank and put a sump pump, or two for redundancy, in the Mayfran. The coolant comes out of the machine into the Mayfran, immediately gets pumped out into a filter, which drains into the main tank nice and clean. All pumps pull from the main tank. If the Mayfran lets small chips through as long as they are small enough not to cause trouble for the sump pump who cares, the filter will catch them. Bonus to this is you have perfectly clean coolant to your pumps, no baffles so skimming the oil off your coolant is easy, I have a box way mill so lots of oil, and if you have multiple machines then centralized coolant is not much of a leap. I went this route years ago for different reasons and love it.
03-02-2021, 11:29 AM #30
Ohh yea! Been playing with all that for a while now, LOL. I have probably re-posted my first OP programs 30 times in the name of chip control.
And, countless hand-edits moving the chip-flush around. Right now I have the retention time set @ 25secs. I have found that to be just under the spill threshold.
I also, a couple weeks ago, removed and capped the very front bottom flush tubes (closest to part change station) on each side. This increased velocity from the remaining ports.
That actually helped a lot on the machining side of the wall. It gets a little messier on the floor of the part changing side. But, that is easy peasy to maintain.
I am going to rule out any solution that involves more pumps. I want this as simple as possible. Only thing I want to have to rely on is gravity.
You guys all have great ideas.
But, this has to be something I can complete in one weekend. Has to be dead reliable (gravity). And, fit. I have a very small amount of space to accomplish this.
Ohh, it also has to be cheap!
03-02-2021, 11:49 AM #31
Making a mod using the extra tanks is the best solution. Also, being someone who bought the cutest little cement mixer from Amazon because of a yard project gave me an excuse, I get the want to buy a TIG set up. Don't be cheap. Find a local fab shop to make one of the exisiting tanks to fit the size of your space and then over a weekend you can cut a slightly larger hole in each tank to attach the two tanks together with bulkheads. You don't need to double the amount of coolant just want a bit of spill over room and safety. You also don't have enough time in the day.
03-02-2021, 11:51 AM #32
Modding the coolant tank....and here I thought you were going to have it chromed....
Eefen' It Don't Go Chrome It - YouTube
03-02-2021, 12:15 PM #33
