Hello Guys again,
after months of problems, with the help of this forum, service engineers, mtb and so on , I am getting hopefully close to have my 3 axis VMC running again.
Basically now the machine is let's say working , but I am having an issue setting work offsets.
I did look at other threads but I couldn't see one which describes the same problem.
I try to explain this as good as I can , so:
Basically I lost all parameters , so I had to re load everything( all parameters except PMC were the ones I transfered via RS232 prior to memmory all clear) , that seems like it worked.
Now, I have been using the same method to set work offset on x and y on Fanuc for 18 years , which is basically find what ever point then go on G54/G55 and type x0, measure(soft key) , y0 measure(soft key) , but when I look at the absolute position screen , it shows instead of x0 and y0 , it shows for instance something like x-0.04mm y+0.005mm , also when I press reset it does strange things like it resets the z datum to the absolute position set on g54/g55 work offsets.
I don't understand what is going on , I might try to record a little video as I find difficult to explain otherwise.
Just another detail I noticed doing this ( it might have been like that before I am not sure) , once I reset , if I was on g90 for instance , once I press reset button g91 becomes modal.
Many thanks in advance.
