Considering small CNC mill - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21
    Nov 2019
    FINLAND
    41
    22
    Quote Originally Posted by barbter View Post
    The RS232 port!
    Oh no. I thought that it is printer port, but it seems it needs special cable... Thanks.
  2. #22
    Nov 2019
    FINLAND
    41
    22
    While doing complete cleanup and lubing (it's incredible how much chips can be in all the crevices!) I noticed there is small play in X-axis ballscrew clutch. I can't see how it could be worn but still ask it. Should this be completely without play?
    How is the position told to the controller as I'm not finding a single glass scale on that machine? Is it only the servo motor spin which tells the position. Then I'd think no play is allowed. Except if that play is taken into account in the controller program.
    Another thing. All the wipers from telescopic covers were shot. Hopefully it will work to replace them. It seems Dynatect PR2 is the correct wiper lip..
  3. #23
    Dec 2008
    New York
    10,234
    2656
    i wouldnt buy any machine unless you get a complete set of operator, programming and maintenance machines that came with that particular model
    literally the manuals are important. its like buying a combination safe and not knowing the combination for the lock
  4. Likes majohnson liked this post
  5. #24
    Nov 2019
    FINLAND
    41
    22
    Bit confusing that the machine is designed so that Z axis can lower only that far.
    I wonder what might the machine designer thought.. Basically you can't machine anything clamped on the table and even the vice had to be very tall to work. Any suggestions for riser block or other thoughts?
  6. #25
    Oct 2007
    SPAIN
    3,643
    2067
    1348
    They are specced in different height raiser blocks for the Z column. 100mm, 200 (std in Europe) etc.
    It was to allow whatever automation you wanted to use on it (none, 4axis, 5 axis, pneumatic clamping etc).
    All you need do is make an aluminium sub plate to raise up the vice
  7. Likes DouglasJRizzo liked this post
