Wolfram Malukker
- Jan 19, 2019
I'm about halfway through the design phase of a hobby HMC for my home garage. I've built a VMC and it worked well in the 1HP spindle class, would do everything a Bridgeport would do as far as cutting power. This time, I'm going for a Horizontal.
It's a linear rail based machine, on an steel skeleton frame that's encased in polymer concrete. The base casting that will hold the Z and Y axes will weigh in around 1300lbs. The Vertical X axis will weigh around 450lbs. (weights are estimates based on volume and solid models)
The spindle is a Chinese import BT30 spindle, which is surprisingly well machined and hardened. I was anticipating a rough part but really it's a bargain for what I got. The bearings in it may wear out in a year but they are standard sizes and are P4 grade...well...marked as P4 grade. I did throw all the cap screws out and cleaned and retapped all the blind holes, and replaced all the cap screws. Spindle runout was measured with a nice little 0.0001" resolution indicator and barely twitched the needle on four contact points inside the taper. I'm a bit concerned about bearing protection, but they do have a labyrinth style seal protecting them in the front.
The linear rails are 4-point contact 25mm section width-same as the Haas Toolroom mills. They're Hiwin brand, and are "medium" preload. The rails at hand will allow for a 12"x12"x15" work envelope.
The spindle is driven by a 5M-HTD style belt, two belts 20mm wide.
What kind of horsepower spindle motor do I need to be looking for? The spindle is rated for 6000RPM continuous operation. I'm thinking 1 or 2HP would be enough, but if a machine this size with a 5MHTD needs a 3HP motor to play the game, well, I'll make the spindle mount big enough to handle it.
It's not in the class of a Speedio for sure, but it will do for garage work. Hopefully it'll do for a little paying work, until I can afford to buy a Kitamura or a Brother one day!
