rupertm
- Jun 12, 2013
- Amity, Oregon
Thanks for reading. This is a long and complicated post.
Im looking for a few ideas on what might be causing some issues with a 1996 Matsuura RAIIIF. It has the Yasnac I80 controller. I got the machine a 6 months ago. I have been cleaning it up and as Im starting to try things like actually start cutting something Im running into a few issues. First and most troubling issue is the keypad on the controller. It stops working. The machine will be up and running and Ill see the all of the leds on the control panel flicker and blink a few times. They all do it together at the same time. Before that happens everything is running and then after I can still manually move the table, twist the knobs and the readout on the crt updates, but they keypad stops doing anything. The key beep is gone. I have to power cycle the controller to get the machine back to where the keypad works. This issue I had last spring after getting the machine, but over the summer it was gone, but has returned this fall. The previous owner had it in a shop with little ventilation and all the controller cards are covered with a thin layer of grease which I think is condensed coolant(Blaser) from out of the air. I think I have all the parameters backed up on a attached computer. Im tempted to remove the cards and wash them with 100% Isopropyl alcohol being cautious of the switches or any open components. Does anyone think that is a poor idea? If not can anyone confirm for me all the different parameters I need to make sure are backed up before removing power, cards and the backup battery. I have the following. Or should another completely different course of action be tried?
Programs, O00100, O00200, O09901 (which are pallet changer programs)
"All Parameters",
"Macro Common",
"Offsets".
Am I missing any?
Second issue involves homing the machine. Upon getting the machine I have since pulled all the ways covers and vacuumed out all of the chips that had built up inside the machine. I did not have the coolant running at that point to hose that area down, so there are still some very small steel chips in and around the areas under the covers. But most of them are gone. What Im seeing for a failure is the Y and X axis's are homing and them shutting down the machine. I have to press the power on button and reset and use the handle to manually crank the table back off the softstop( Im guessing). I have seen this on both X and Y. A new issue which just started yesterday was a error 2082: ZR DECLS ERROR. Started getting that on Y and Z. Im at a bit of a loss as what I should try doing here. Does anyone have any ideas or suggestions?
Thank You
Matt
"All Parameters",
"Macro Common",
"Offsets".
Am I missing any?
Thank You
Matt
