If a Google search does not get you there, you could always just test it with a meter.
This appears to be a DC brushed servo motor, with tachometer speed feedback. Therefore it needs:
- Two wires for armature power
- Two wires for tachometer feedback
- One wire for case ground
- Optionally, two wires for a holding brake
Make yourself a 7x7 data table, and measure and record the resistance between each pair of pins.
The pair that have between 1 and 5 Ohms between them are probably armature power.
The pair that have somewhat higher resistance (maybe a few tens of Ohms, maybe a few hundred) are probably the tachometer
The one that does not connect to any of the others, but connects to the motor case, is ground.
If you can turn the shaft by hand with no power applied, then the motor does not have a brake. If you cannot, then it probably does.
A pair of pins that lead to the brake would probably have higher resistance than the tachometer pair.
It is possible that the armature power leads are doubled: two pins to one side, and two pins to the other. In that case you will see two pairs that have nearly zero resistance within the pair, and between 1 and 5 ohms to either of the other pair.
