Coolant mixer
Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: Coolant mixer
    Sep 2016
    Tennessee
    95
    86
    40
    Default Coolant mixer
    What are you guys using to mix your coolant? We are currently using this https://www.mscdirect.com/product/details/02036606 , but the mix ratio is never spot on, and it stops working after a couple of years. I worked at small job shops before, and we would just dump the concentrate in the tank till it read correctly on the refractometer.
    Nov 2014
    Florida
    6,017
    2376
    2988
    I worked at one place that used a mixer, but was designed for use with a 5 gallon bucket. Much more portable that way, and cheaper to replace when/if it dies...
    Other than that, no help, sorry.
  3. Likes primeholy liked this post
    Feb 2014
    FL
    4,013
    13030
    4787
    Straight oil. No mixing.
    Easy peasy.
  5. Likes primeholy liked this post
  6. #4
    Sep 2016
    Tennessee
    95
    86
    40
    Quote Originally Posted by TeachMePlease View Post
    Easy peasy.
    That trim gets expensive, but IT AINT MY MONEY!!
  7. #5
    Feb 2013
    Madison, WI
    1,212
    1263
    783
    Pour a bit into a 5 gallon bucket of water. Mix with a paint and mud mixer in a cordless drill. Dump into coolant tank.
  8. Likes primeholy liked this post
  9. #6
    Jun 2018
    Idaho
    170
    68
    44
    This is what we use. I can't remember how many years I've had It. Still works like a champ. About $100 cheaper than the one you linked to.
    Mini-Jetmix
  10. Likes primeholy, kineticmx liked this post
  11. #7
    Nov 2015
    Colorado
    160
    28
    57
    I can see a coolant mixer coming in as a huge time saver in a big shop with machines all using the same fluid.
    Small shops, eh. Just mix it by hand
  12. Likes primeholy liked this post
  13. #8
    Jan 2020
    Connecticut
    44
    51
    14
    Quote Originally Posted by AARONT View Post
    That wouldn't have worked at my last shop. We were adding 200 gallons of coolant a day! We had a mixer that pulled coolant from a 55 gallon barrel on wheels with a hose that fed it from a spigot on a pole. We would just wheel the barrel to where the coolant was needed and open the inlet valve to the mixer.
  14. #9
    May 2017
    Minnesota
    1,681
    2164
    1111
    Automatic Coolant Refill
    And for the saw, I just spray from the coolant hose.
  15. #10
    Feb 2012
    1,510
    933
    1684
    Venturi mixers rely on incoming water pressure, which can fluctuate.
    The dropping level of coolant in the drum also affects the mixture.
    Mixers going bad after a few years is probably due to contamination. Clean and rebuild.
  16. Likes primeholy, blkaplan liked this post
  17. #11
    Apr 2007
    Pillager, MN
    6,178
    1925
    5922
    5 gallon buskit model? You remember what brand?
    I only buy in 5 gallons...............most mixers are for 55 gallon drums...................anyone know of a bucket model?
  18. Likes primeholy liked this post
  19. #12
    Jun 2018
    Idaho
    170
    68
    44
    I only buy in 5 gallons...............most mixers are for 55 gallon drums...................anyone know of a bucket model? [/B]
    The Mini Mixer I linked to earlier Is a bucket model. We just made an adaptor to fit a drum and extended the pickup. Works fine.
    PMIS- MIXERS
    oip.jpg[B]
  20. #13
    Jun 2018
    Idaho
    170
    68
    44
    And if you want a drum mixer here is a steal of a deal on Ebay
    COOLANT JET MIXER PROPOTIONER | eBay
  21. Likes primeholy liked this post
  22. #14
    Sep 2016
    Tennessee
    95
    86
    40
    Quote Originally Posted by metalmadness View Post
    Yeah, every other place I worked we just dumped coolant in a bucket, added water, then cycling it through the machine would mix it well.
  23. #15
    Nov 2010
    Tustin, CA
    484
    322
    149
    I've been looking around and I've heard from a few people this works well with 5 gal buckets.
    Groz Plus Venturi Mixers for Metalworking Fluids (Coolants, Cutting Fluids) and Cleaners | Coolant Consultants, Inc.
  24. #16
    Jul 2006
    Arizona
    4,720
    18853
    4569
    Here's my home brew solution to a venturi coolant mixer. I bought a $5 aquarium fish tank venturi pump and added a precision flow metering valve from McMaster Carr and a few fittings. The plastic ball valve that came with the fish pump (in the assembly pictures) was not able to be easily adjusted, but the concept worked great.
    Total cost was $70 and it works very well. Been using it for the past year now.
    McMaster-Carr
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Attached Thumbnails Attached Thumbnails 20190428_111131_resized_1.jpg   20190420_152647_resized.jpg   20190420_152655_resized.jpg
  25. Likes wheelieking71, BGL liked this post
  26. #17
    Apr 2007
    Pillager, MN
    6,178
    1925
    5922
    Quote Originally Posted by Philabuster View Post
    McMaster-Carr
    I like the looks('n cost) of that.....................
  27. #18
    Nov 2016
    Maine
    5
    I bought this product from MSC a year ago. Use it every day between 3 machines that use the same coolant. No issues yet. https://www.mscdirect.com/product/details/09407008
    It saves us almost $500 buying the 55 gallon drum over the same amount in a 5 gallon bucket. Seems as the the drum has lasted longer too.
  28. Likes primeholy, Bluejeep liked this post
  29. #19
    Jan 2014
    Oregon
    666
    165
    474
    After screwing with venturi mixers and buckets for way too long, I bought a Dosatron last year. No more worrying about coolant BS. Just put the inlet in the drum (or bucket), set the mix %, and get back to work.
    The best thing about the dosatron is it works just fine if you have low flow coming out of a filter stack.
    Dosatron Water Powered Dosing Technology | Dosatron
  30. Likes chucker, BGL liked this post
  31. #20
    Dec 2003
    poulsbo, wa, usa
    1,115
    88
    477
    I use a GROZ and have for years ,,, it works great and I can adjust it to what i need ,,, its not dead nuts on the mix but gets me in the ballpark and I have a easy time keeping the machines between 7 and 9% ,,, I just put a bucket of coolant mix on a cheap little hand cart and drag the hose around the shop ,,,
