Coolant mixer - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
Thread: Coolant mixer
  1. #21
    Jul 2015
    UNITED KINGDOM
    183
    340
    46
    I made one about the same as post 16, cost under £30.
    one thing I did do is set up a tap with an electric valve and a timer wired in. set the timer so it fills whatever buckets you use to get it to the machine about 3\4 full to account for pressure changes and you have no worries about forgetting about it and flooding.
  2. #22
    Aug 2006
    Cape Cod, Ma
    512
    267
    127
    Quote Originally Posted by Pat (pti) View Post
    I bought this product from MSC a year ago. Use it every day between 3 machines that use the same coolant. No issues yet. https://www.mscdirect.com/product/details/09407008
    It saves us almost $500 buying the 55 gallon drum over the same amount in a 5 gallon bucket. Seems as the the drum has lasted longer too.
    I've been using that same one for going on 20 years, no problems.
  3. #23
    Mar 2006
    PHILIPPINES
    3,019
    1091
    1452
    Personally I don't like any premixers. It seems operators just look at the coolant being low then head over to the drum and fill the machine up with premixed THEN check the mix at the machine. Always waaay above 6-7. By this point the tanks full and in order to thin the mix they put a bucket on the table and pump it out. Then start guessing as to what they should add. Seems so many have a hard time with the concept of evaporation.
    It sucks walking up to a machine that looks like they've been using glue for coolant.
  4. Likes BGL liked this post
  5. #24
    May 2017
    Minnesota
    1,647
    2132
    1081
    That's why I like the automatic mixer on the Haas. Machine tells me it's low, I check the mix, if the concentration is low I bump the mix ratio and hit the button. If it's high I drop the ratio and hit the button. If it's good, just hit the button.
  6. #25
    Nov 2007
    Hamilton, Ontario
    1,182
    846
    451
    How do most of you check your coolant in the tank. I have been using a refractometer. But the instructions say it's only for fresh coolant. Should I be getting testing straps? I have been going though a fair bit of coolant and yet the ratio has not been getting a lot richer.
  7. #26
    Apr 2007
    Pillager, MN
    6,178
    1924
    5920
    Shudda bought one years ago...............works pretty good. Just drag it to the machine and start filling................................
  8. #27
    Nov 2010
    Tustin, CA
    482
    321
    148
    Quote Originally Posted by Pattnmaker View Post
    With a refractometer and just run the coolant and grab a few drops after it shuts off.
