Coolant operation - pumps on, no flow: other interlocks? Matsuura
Results 1 to 9 of 9
    Apr 2015
    New Mexico
    202
    16
    13
    Default Coolant operation - pumps on, no flow: other interlocks? Matsuura
    Hello,
    I have a matsuura MC760
    I just reconnected the coolant system after transport. I put enough fluid to cover the end of the inlet of the pump. I run M8 and I can hear the pump turn on but I don't get any fluid out of the nozzles at the cutter.
    There are on/off valves at the flex tube at the cutters, those are on.
    Is there something else that needs to be 'active' to allow coolant to get to the nozzle?
    Do I need to perform some sort of bleeding/priming of the pump?
    I tried to reverse two of the phases to see if it was spinning backwards, no change.
    Any thoughts?
    David
    Aug 2010
    Connecticut
    1,920
    1485
    2034
    On one our machines(Not a Matsuura), we have to prime the pump.
    On ours there is a 12mm wide (or so) set screw that can be removed, then fill that with coolant.
    Obviously you know as mentioned to make sure the motor is turning in the correct direction.
    Apr 2015
    New Mexico
    202
    16
    13
    Quote Originally Posted by Alloy Mcgraw View Post
    Ah cool, yeah there is a large hex screw in the top. Ill try that, thanks!!
    Oct 2006
    Petaluma CA 94952
    539
    77
    I just installed a DMG machine here that sat for some years. It had the same problem, there was a spring loaded check valve in the coolant block at the spindle. It was gummed up. I had to heat it up and blow air from the pump side.
    Aug 2002
    West Unity, Ohio
    25,531
    5766
    8160
    Switch any two wires on your incoming power.
    Think Snow Eh!
    Ox
  6. Likes gustafson, Chip Chester, aj liked this post
    Sep 2005
    Oakland, CA
    2,529
    321
    685
    If you reversed rotation and that did not fix it, you may have a gob of crap stuck in the plumbing somewhere. There is probably a check valve in the path- check that and then just work backwrd or forward from the pump until you figure it out.
    Aug 2002
    West Unity, Ohio
    25,531
    5766
    8160
    I missed that last line the firth time.
    Think Snow Eh!
    Ox
  9. Likes Cooperstock liked this post
  10. #8
    Jan 2017
    Oregon
    2,736
    482
    1944
    Quote Originally Posted by Cooperstock View Post
    Hello,
    Might try a little more fluid. Just covering the inlet isn't really enough. Centrifugal pumps usually self-prime, but it could be pulling the level down and sucking air.
    I'd try running a hose into a bucket of water just to make sure...
  11. #9
    Apr 2015
    New Mexico
    202
    16
    13
    Thank you all, I got it working:
    Pulling the vent set screw on the top of the neck right before the pump allowed me to pour fluid into the pump (that seemed to prime it).
    I set my phases back to the original connected U-V-W rotation and it worked when I turned it on. I topped off the coolant tray and it seems to be up and running.
  12. Likes Ox, Greg White liked this post
