I am currently cutting some 1/2" dovetails on 6061 aluminum with a 3/8" x 45 degree carbide dovetail cutter and I'm having some burrs on the entry and exit of the dovetails on the bottom most faces and the 45 degree surfaces. I am edge breaking the top edges of the dovetails but obviously I can't reach the other edges to deburr. I am trying to do this without moving the setup as 100% of the part is done in the same static setup. I have tried running along side them with an abrasive brush but it isn't strong enough to take the burrs off. Any suggestions on a tool that could work in this situation? I'm trying to set this up as a completely automated part, so doing them by hand isn't realistic with the run amount I have to do.
Anyway thanks in advance!
