Coolant problem?
Results 1 to 7 of 7
    Mar 2015
    39
    39
    9
    Question Coolant problem?
    I have a machine that cuts mostly copper.
    It's been running alone just fine for a year and a half.
    Now all the sudden the copper comes out tarnished and cloudy.
    I have to really work to get the tarnish off and sometimes I can't get the cloudy surface to polish out without a LOT of work.
    Not enough money in each individual piece to justify the time to polish it.
    Another hint is that my coolant foam is blue colored! Hints of Copper Sulphate...
    The coolant is the same I've always used, qualichem extreme-cut 250C and it's less than one year old.
    I only use filtered water to top off the tank.
    Any ideas?
    Thanks in advance.
    Dec 2008
    New York
    10,033
    2609
    Quote Originally Posted by jdholbrook33 View Post
    Any ideas?
    Thanks in advance.
    many coolant salesman will take coolant samples and analyze it and tell you whats wrong with it. when you got a 2000 gallon central coolant system connected to 4 machines, monthly testing of coolant is normally done. summer time the water to concentrate ratio often swings more than desired due to evaporation increase in warmer summer months
  3. Likes jdholbrook33 liked this post
    Mar 2006
    PHILIPPINES
    2,342
    464
    682
    Just filtered water or deionized? I was using Trimsol LC specifically for copper and started getting spots. I finally found that one of the new guys on nights had been topping off with tap water. changed everything out and was back to normal.
    Over a year and a half your machine surely had to get way lube in the coolant. I would say machining copper for over a year you definitely got your moneys worth out of the coolant
  5. Likes jdholbrook33, primeholy liked this post
  6. #4
    Jan 2003
    Canada
    11,175
    5214
    3315
    Could be PH level? Copper loves to take finger prints(oily acid eh?), doesn't take much to tarnish that crap.
    Probably time to change it anyhow.
  7. Likes jdholbrook33 liked this post
  8. #5
    Aug 2002
    West Unity, Ohio
    25,071
    5310
    7827
    I too would say to check the PH level.
    First - you need to find what your target range is. (from Qualichem))
    I bought and hated the test strips that I got from MSC or McMaster.
    It took me a while to search out my old supplier as they had gotten bought out apparently, but - I found them:
    "pH Paper"
    Fil-Chem Inc
    Paul Frank Division
    Raleigh, NC
    919-878-1270
    Fil-Chem.com
    Think Snow Eh!
    Ox
    Last edited by Ox; 07-11-2019 at 09:10 AM. Reason: (from Qualichem)) and added link
  9. Likes jdholbrook33 liked this post
  10. #6
    Mar 2015
    39
    39
    9
    Thanks for the advice.
    I contacted my supplier and they are sending a man out to check the coolant.
    It's only been in there about 6 months but there has been a LOT of copper run through that machine.
    I'll come back with the results.
    Thanks again,
    James
  11. Likes Ox liked this post
  12. #7
    Mar 2019
    UNITED KINGDOM
    143
    23
    My first mentor used to poor his cold milky tea in the coolant. It used to develop this skin that was science experiment level.
