Thanks all, so the ideal key to keeping coolant from getting gross is agitation?
Yes and No... The main thing is don't ABUSE IT... Don't piss in it, don't drown possums in it,
don't spit your sunflower seeds in it... Just do your best to not add shit that isn't more coolant,
oils(even tapping oils *could* cause a problem), bleach, pine-sol etc.... I've even run into
problems sharing space with a wood worker.. When he was creating really fine sawdust that floated in the
air, it would get in the coolant and it would start stinking.
ANYTHING that some little bastard bacteria
could possibly think is food... And Bacteria are sneaky little bastards, they evolve FAST.. And them
f@#ers can eat anything... Ever leave a dirty bleach bucket kicking around for a few days??? It smells
like a dumpster fire... WHY? Some little bacteria bastard decided that bleach was yummy, and now he's
eating bleach and shitting, and you are smelling his shit... At the homestakes gold mine up in S. Dakota
(closed now).. They had a tank of bacteria that ate ARSENIC... F'n ARSENIC.. If I had some arsenic, I bet
I could also "evolve" a strain of bacteria that ate arsenic in less than a week, using nothing nothing
more than a couple of buckets on my back porch.
As far as agitation, its the whole Aerobic an Anaerobic bacteria thing... You need to treat your sump
like a fish tank.. Bacterial balance. Bacteria A eats Bacteria B's shit and vise versa. If you
aren't putting more oxygen into the fish tank/coolant, then the aerobic bacteria all die, and then there
is nobody there to eat the anaerobic bacteria's shit... And shit stinks.
Think about the difference between a stagnant puddle and a running stream.
I also read that it is important to keep chips from getting in your sump. Being that I use a lot of roughing end mills, it is tough to control those tiny chips. Any special filtration that you do to keep those small chips out of the sump?
Chips in the tank happen. Shovel 'em out once in a while.. (like vacuming the gravel in a fish tank)
You also end up with tiny tiny tiny microscopic
fines in the coolant which can act as an abrasive. Occasionally you *should* pump all your coolant out, and
decant it (I think thats the right word). Just let it sit for 4 or 5 days.. It will let all the tiniest little
oil droplets that don't belong in there to float to the top, and the tiniest little gritty shit to sink
to the bottom. Suck the oils off the top and drain off all the coolant except for the last little tiny
bit at the bottom. That's the cheap way to do it... They make all kinds of fancy expensive contraptions
that do that stuff on the fly also.
If you have some well used coolant, put some in a clear bottle, put it up on top of the control and let
it sit for a few days... If there is grit at the bottom of the bottle and oil at the top, you have some
maintenance to do... (This is a do as I say, not as I DO moment).
Just think "Fish Tank" and you'll be fine. AND don't buy crap coolant.
