Busted Knuckle
- Sep 26, 2012
- Houston,TX USA Earth
A pretty strange one here. I have a Takumi V11 vertical mill with a Fanuc Oi-MD control. My issue is the coolant and interior work light will both shut off instantly once a spindle speed or feed/rapid command is issued. This happens in auto as well as MDI. The problem is persistent and is not random, happens every time without fail. This machine is only a few years old and the problem only started yesterday.
I cannot find any short, the relays in the electric enclosure are fine (green lights), do not see any loose connections, etc. Also no alarm comes up on the control. Once off I cannot manually turn the coolant or work light back on without a power down/re-boot of the machine.
I had a tech out yesterday looking at it and he could not find any fault.
Any help to lead me in the right direction would be much appreciated.
