Counterboring in aluminum on lathe with live tooling
Results 1 to 17 of 17
    Aug 2012
    New Jersey
    102
    23
    39
    Default Counterboring in aluminum on lathe with live tooling
    Has anyone else had problems counterboring aluminum? The counterbore tool broke. When I tried an endmill (3000 rpm, 6 ipm), chips welded together and jammed up. It's a simple 15mm CB 8.1mm deep. Maybe flat-bottom drills? I rarely work with aluminum and I am starting to feel like an idiot.
    Gene
    Jan 2015
    Missouri
    1,552
    233
    978
    Do you have coolant on it
    Don
    Sep 2013
    PA
    559
    272
    435
    Coolant or cutting oil is important. Are you circle interpolating the hole or plunging it? Not to be rude but it's like the easiest material to work with.
    If it's some sort of 6063 it's more prone to being gummy but a good tool and coolant will take care of your issue.
    Feb 2006
    Minneapolis
    240
    12
    35
    If you don't want to use coolant there are some materials that tend to clog less - TiCN coated carbide works fairly well dry.
    Feb 2014
    FL
    4,589
    13941
    5607
    Quote Originally Posted by BobM3 View Post
    Zrn coated endmills also work dry.
  6. Likes DouglasJRizzo liked this post
    Nov 2013
    Utah
    5,107
    1336
    2911
    I know this seems like a very non-conventional way to do it, since you have Live Tools. Have you considered using a Boring Bar?
    R
    Jun 2011
    New Jersey
    1,717
    933
    753
    R
    Exactly. I have these fine boring bars from Kaiser Thinbit that work great in this kind of application.
  9. #8
    Aug 2012
    New Jersey
    102
    23
    39
    R
    In an adjustable boring head? I've never used one in the lathe, only the Bridgeport and the radial drill. I'm not sure it's worth messing around to set the size for the 3 parts I have left. Plus, I don't think I have a small enough boring head.
  10. #9
    Aug 2012
    New Jersey
    102
    23
    39
    Quote Originally Posted by D Nelson View Post
    Don
    Not thru tool, just flood (and it is not easy to aim it properly).
  11. #10
    Feb 2014
    FL
    4,589
    13941
    5607
    Quote Originally Posted by Tungsten Carbide View Post
    Might I suggest you check these guys out to solve that problem?
    Home - QPM Products
  12. #11
    Jun 2012
    FLORIDA
    102
    28
    Gene
    3000 rpm's too high? I usually do below 1200.
  13. Likes Ox liked this post
  14. #12
    Feb 2014
    FL
    4,589
    13941
    5607
    Quote Originally Posted by KENMASTERS View Post
    That would be less than 200SFM...
    What's your cutter material? Cheese?
  15. Likes LockNut, lumley32, Mtndew liked this post
  16. #13
    Aug 2002
    West Unity, Ohio
    27,746
    8083
    9802
    Just doo to the nature of the cut (this is an endmill c/b a drilled hole - eh?) if the live toy has any wear in the bearings - at that speed, it would likely turn to a chattery nightmare, and blow the tool.
    This aint the same as interping.
    I too would drop down to 1000rpm, but I would prolly leave the feed where you have it. (IPM)
    Think Snow Eh!
    Ox
  17. #14
    Aug 2007
    Great Lakes USA
    307
    46
    49
    Sometimes it’s a “duh” moment … is your c-axis brake mcode present in the program prior to the counterbore cycle? Speaking from experience here because duh, yeah I did that and pop went the em.
  18. #15
    Sep 2008
    Eugene Oregon
    287
    12
    18
    Quote Originally Posted by TeachMePlease View Post
    Home - QPM Products
    Bit of a side note, have you dealt with them before? They told me I had to go through a distributor and I gave up when MSC quote me 175% of what qpm quoted.
  19. Likes Ox liked this post
  20. #16
    Feb 2014
    FL
    4,589
    13941
    5607
    Quote Originally Posted by DMSentra View Post
    Not directly, I buy through a distributor and I'm quite happy with the product. Sadly, I don't think either of the guys I buy through covers your area, or I'd give you a contact.
  21. #17
    Aug 2012
    New Jersey
    102
    23
    39
    Thanks for all the input. A flat bottom Allied TA drill and a better coolant nozzle got it done. I guess they clear the chips better than plunging a 4 flute endmill.
    -Gene
