adamm
Cast Iron
- Sep 19, 2008
- Kingston, ON
I bought a replacement mainboard for my 6T controlled lathe on eBay. It has the same model number, and looks the same as the one that came with the lathe. On the lathe, the C08 port is used, and on the replacement board, there is a little plastic clip blocking the C08 port. Does that mean anything? Did Fanuc put those on if the port is not electrically hooked up? I've attached a picture of the cover.
Adam
Adam
