Hi all,
I have a CTX 400 Serie II Gildemeister cnc lathe (fanuc controler) and have major problem with the turret.
In MDI mode I can call any tool and it will index every time.
In memory, while running a program, at the first tool change command, if the right tool is already in place a program stop occures and I cant continu (start)machining. If the turret has to index, it unlocks, start to rotate a bit then the alarm 1013 -tool holder not locked- occure. This happens every time I start a program (not every, let say 249 times out of 250 try.) It is even more mind bugging when once in a while it works for no reason! Something interesting, the program I run is self repeating, and if by a luck I can start it, it never stops and there are 3 tools changes in a single run.
Thanks, Maxime
Thanks, Maxime
