A curious case of exploding end mills
Page 1 of 3 123 LastLast
Results 1 to 20 of 53
    Jan 2016
    176
    28
    91
    Default A curious case of exploding end mills
    I had an expensive day today and I am trying to figure out why.
    This 6061-T6 part has a number of 0.196" wide slots, either 1.417" or 3.346" long, 0.127" deep. Roughed them out with a ramp down at 2 degrees to full depth, leaving 0.005" per side for a finish pass later on. I was using Helical H40ALV-3 1/8" end mills in either Kaiser NBC with on-size collets, MST shrink-fit collet holders, or ER collet chucks. Running on a Speedio. Very good chip evacuation with flood coolant (Trim 690XT).
    I blew up no less than six end mills. Even for me this is egregious.
    I kept backing off the speed and feed, and ended up at very conservative full slotting numbers (16000 rpm, 19 in/min, 0.060" ramp depth). The broken end mills were pristine -- no broken tips, no visible wear, no chip welding whatsoever. Four of the six broke inside the nose of the collet, which trashed two collets and two shrink-fit collets.
    That ran me out of 1/8" aluminum-specific end mills, and I needed to get the part done, so I grabbed a random 1/8" 4-flute and ran that. It finished the job without complaint.
    Maybe a bad batch of carbide from Helical? Those were all ordered at the same time, and have sat in my drawer until today.
    I'm just pissed at scrapping a bunch of tooling and I'm trying to figure out why.
  2. Likes woodchuckNJ liked this post
  3. #2
    Jul 2006
    Hillsboro, New Hampshire
    12,948
    2938
    8932
    Check the flutes on the ends for an improper primary radial clearance. If any of the original cylinder was left from the blank they would cut poorly, with excess bending load on them.
    Did you notice any "berm" buildup in front of the cuts? Any other unusual behavior?
    It's also possible that they had a bad batch of carbide rod with internal cracking. How do the broken ends look? Uniformly granular, or are there shiny areas, or other discontinuities?
    Pictures, as ever, would help here.
  4. Likes trochoidalpath liked this post
  5. #3
    Jan 2016
    176
    28
    91
    I don't have a way to measure the primary radial clearance, but under 10X magnification the flutes look properly ground to me (not an expert by any stretch).
    There was no buildup in front of the cuts. They just exploded. During cutting they had the usual little squeak at entry but otherwise seemed pretty normal. Some made it only a few slots, one did about 50 before it gave up.
    I remember at least one broken end has some shiny patches in the cross-section. Usually the cutting end went "ping" and fell out, there was a retained short disc of carbide debris in the collet, and then the remainder of the shank was in apparent good shape.
    I have at least a few of the end mills in the Bucket of Shame, so I can grab photos the next time I'm out at the machine.
  6. #4
    Jul 2006
    12,948
    2938
    8932
    Getting pics will be good, try to make them as large and clear as possible.
    On the two bad shrink holders, you can probably trim the ends to clean metal and re-chamfer, as long as there's not a slug left currently that you can't remove. Even then, you could trim back, leaving a thin ring of steel, then try scoring the ring to allow it to break off. It may not be worth the effort, but WTH...
  7. #5
    Jun 2011
    New Jersey
    1,498
    798
    651
    Blowing up end mills sounds kinda cool. Like home made fireworks. Mine just break, and fall into the chip conveyor.
    Ok, seriously, is there enough spindle RPM to do what you want? Maybe you're short on RPMS. The machine sounds pretty capable, but that's a small dia end mill.
  8. Likes Trueturning, toolsteel liked this post
  9. #6
    Sep 2010
    Oklahoma City, OK
    5,479
    1057
    2391
    1/8" 3fl, 19ipm and 16k = ~.0004ipt and ~520sfm. Those seem like pretty safe parameters to me.
    I'd guess chip evacuation, maybe the 4fl had enough core strength to suck up the difference? Can you go to a mist arrangement?
    How's your TIR? I know you're using good tools and holders in a good machine, but it's worth a look. Even .0002" is 50% of your feed....
    PS- I wish I had a good graphic of how TIR changes tooth loading in tools based on eccentricity and timing to a tooth or gullet.
  10. Likes trochoidalpath, toolsteel liked this post
  11. #7
    Jun 2013
    Oregon
    1,848
    679
    1141
    Might sound too simple, but if you are running soluble oil, is your concentration o.k.?
  12. Likes trochoidalpath, doug8cat liked this post
  13. #8
    Jan 2014
    Oregon
    766
    193
    562
    We have had quality issues with Helical lately. They are still our goto for finishers, but we got a batch of .125 or .187 40 degree endmills with relieved shanks in the other day where the grind on the shanks was so bad I could see they were garbage from 10 feet away while they were still in the sleeve.
    They did send us out new ones promptly, but they were nowhere near as apologetic or excited about the quality escape as I would have been if we sent out parts that looked like that.
    Helical also sells a couple geometries that just don't perform as advertised (looking at you 45 degree AL roughers). Not sure why they keep that crap in their catalog when they know it doesn't work.
  14. Likes trochoidalpath liked this post
  15. #9
    Jan 2016
    176
    28
    91
    Quote Originally Posted by Gobo View Post
    I checked the concentration and if anything it was a little high. I usually aim for more like 8%, yesterday it was 9.5% (the design concentration for 690XT is 7.5-10% if memory serves).
  16. #10
    Sep 2007
    Washington
    5,676
    280
    1893
    Quote Originally Posted by trochoidalpath View Post
    This ^^^
    Given all the other info, this points strongly at a bad batch of endmills.
    Regards.
    Mike
  17. #11
    Jan 2016
    176
    28
    91
    Quote Originally Posted by Cole2534 View Post
    I have a TDC coolant manifold, and it was dumping coolant from around 120 degrees. I never saw any chips in the slot, part, tool, anything. No reasonable way to go to a mist setup on the Speedios.
    I confess I didn't measure TIR in the spindle. I used separate toolholders, so if it was a TIR problem, it has to be in the spindle... which seems unlikely for a Speedio that hasn't ever been bumped. But worth checking.
  18. #12
    Oct 2010
    Oregon
    5,703
    5569
    2164
    Before I jump to conclusions based on the endmills breaking inside the collet, let me ask if they broke at the tops of the flutes, broke right across the cylindrical shank, or broke the flutes somewhere below the top. Post #3 sort of suggests the second case, which would be due to bad endmills.
  19. #13
    Jan 2016
    176
    28
    91
    Quote Originally Posted by sfriedberg View Post
    One broke in the middle of the stick-out, but the flutes were intact.
    Four broke at the shank inside the nose of the collet. The broken face was recessed relative to the collet face. The broken end chewed up the collet on the way out.
    I hope that helps clarify?
  20. #14
    May 2016
    Ohio
    745
    206
    243
    I sell Helical as a distributor. We do see quality issues from carbide spring up randomly. If you had that much trouble with such a simple application and variety of holders. It's probably not you as long as your program isn't doing something it says it isn't.
  21. Likes bryan_machine liked this post
  22. #15
    Feb 2020
    Alabama
    366
    151
    104
    Try a 2 flute.
  23. Likes Trueturning, ElCrasho liked this post
  24. #16
    Jul 2019
    Florida
    3,979
    3908
    783
    Take the tool out of the spindle and clean the inside of the spindle taper. Check how many chips are getting into your carousel and on the tapers on the other tools.
    Check the taper on the holder you are using for mashed chips. Check all of your tools in your carousel and clean all tools and carousel of any chips. You are flinging chips at very high speeds. I thought you had a three flute end mill not 4?
    It may only be a matter of seeing where there are ops where a lot of chips fly mixed in with coolant. You should step process each op and blow everything off before the tool change and note chip disposition.
    Only one thing I would consider first. I always note that kind of thing right off. Simple yet very important usually that can be the case when problems seem to pop up out of nowhere.
  25. #17
    Jun 2013
    1,171
    880
    526
    ramping at 2° you'd get to full depth in short order, which at .127" is the full dia (1xD). Combine that with .0004 chip load, quoted, it sounds like you have a mess of vibration and rubbing the tool to death.
    keep the cut depth under .03 and take an actual chip, is how i'd go.
    6061 is sticky and alloyed with silicon, but it doesn't sound like you have a coolant lubricity or flow issue.
  26. Likes empwoer liked this post
  27. #18
    Jan 2013
    Gilbert, AZ
    7,183
    9536
    9239
    Quote Originally Posted by mkd View Post
    HUH?! You must ramp a whole lot different than I do. My math says a 2' ramp from zero to -.127 will take 3.639"
    Anyways, my money is on bad carbide. And, I freaking HATE when they take the collet with them!
  28. Likes DavidScott liked this post
  29. #19
    Jul 2012
    Washington
    3,406
    1388
    1511
    Considering they broke in the collet or toolholder makes me think carbide. What flute length? You REALLY need to use .156" stubs for that, you can run them a lot harder than 1/8" mills IME. Harvey would be my current pick for that exact size and flute length.
  30. Likes Chris59 liked this post
  31. #20
    Jan 2007
    Flushing/Flint, Michigan
    10,430
    603
    8466
    Quote Originally Posted by Shop Supply Guru View Post
    ........ We do see quality issues from carbide spring up randomly......
    Ouch with a big O. This says something.
    End mill makers do not produce carbide rod and may tend to jump to raw material cost for what seems to be the same basic spec.and mix.
    Some times that jump a good deal and better life, other uses and times not so great.
    Bob
