viper
Titanium
- May 18, 2007
- nowhereville
A couple months ago we were doing a slotting job in 17-4PH with an H900 HT and we are again making them and again pulling our hair out. These are pins that are .3125 diameter and require a clevis type slot in the end that is 1.25in long and all the way through through the part so .3125 deep. The slot is .125 wide.
Before we were using 4FL EMs by Imco. They were varimills and we ran them anywhere from 5900-7500rpm with feeds of .0004-.0008/tooth. DOC also varied from 6 passes to 9 passes. Nothing I did would keep the mills from breaking after about 12-17 parts. Sometimes 20 if I am lucky.
Today, we are revisiting this job and tried some 60 degree helix 3FL mills also from Imco with much sharper edge prep. They made ZERO noise during cutting the first two and then broke on the 4th part. The broke part of the mill showed that two of the the three leading edges of the flutes broke and there was a chip higher up on one of the flutes. I ran these at 7500rpm, 10ipm, and DOC of about .055.
All the varimills we ran showed very little wear or damage on the cutting edges and always broke at the top of the fluted parts which indicate excessive load I guess. All mills are being run with a TON of coolant from three angle and 1in from cutter. If I run dry, the cutter will last one part if that.
I am just doing a linear mill from the open end of the part and because I cannot find much for mills below .125D, I don't have too many options for milling paths. So any ideas here?????
