Cylinder Head Work Port and Polish - Page 2
Page 2 of 6 FirstFirst 1234 ... LastLast
Results 21 to 40 of 117
  1. #21
    Oct 2007
    SPAIN
    5,847
    1678
    913
    Quote Originally Posted by triumph406 View Post
    61 and still putting in 80 hours a week, your a real success story, just sayin...
    Look for some books by David Vizard, a lot of what applied back when he was tuning Minis would apply now.
    Excellent book this!
    Also if you're interested, "twice lucky" by Stuart Turner.
  2. Likes triumph406 liked this post
  3. #22
    Oct 2015
    Oregon
    595
    253
    460
    There are some machines that when you purchase them, you get solid models. I think Centroid has a machine designed for head porting like that.
  4. #23
    Sep 2010
    Anchorage, Alaska, USA
    794
    366
    152
    No, the magic is in the very particular knowledge.
    I think personally that the newer fuel injected motors make all this fuss about magic porting really of secondary importance. Obviously good flow is important, but nowadays if you see a lean spot you get rid of it with the computer. If is caused by poor flow it really is unimportant. Back in the day you have only so many jets and such to change, and if you have a poorly shaped port, it is going to be a compromise somewhere.
    I am just shopping for CAD files.
    Good ones.
    That is all.
    Mark
  5. #24
    Apr 2018
    9,837
    4726
    Quote Originally Posted by snowshooze View Post
    Good ones.
    That is all.
    You may as well kiss it off and quit bothering everybody because no one is going to either give or sell them to you. This is dumb.
  6. Likes triumph406, Garwood, empwoer liked this post
  7. #25
    May 2014
    ca, US
    371
    105
    I have a masters in aero but do not have a flow code so I designed the ports for a new BSA head by drawing it in CAD then 3D printing and testing on a flow bench.
    It is not the best shape since it has physical constraints (valve angle, length, chamber shape, carb size, et cetera) but it changed from 75 CFM at 10" for the stock shape to 96 CFM, which is fairly good.
    Unless you have a complete model of the engine with valve opening profiles, tract lengths and shape, thermal effects and much more, you will not come up with an ideal port shape. Gordon Blair at Belfast University has and engine modeling program that is used by race team engine builders.
    A flow bench will not have the resonance of a valve periodically opening and closing (unsteady flow). If you have a pitot probe that fits down the tract you can find where the flow is separating and improvements can be made.
  8. Likes Turbowerks, SumiSpy liked this post
  9. #26
    Feb 2005
    9,825
    16888
    12045
    Quote Originally Posted by magno_grail View Post
    Just to throw some fuel on the fire.. What is an "Ideal" port shape..
    WHAT is the GOAL? What are we trying to achieve here?
  10. #27
    Sep 2010
    794
    366
    152
    Quote Originally Posted by Bobw View Post
    More ponys out for the motor, I guess.
    Make it burn more gas.
    If they have one for sale, they can fill in the boxes.
  11. #28
    Feb 2005
    9,825
    16888
    12045
    I guess what I'm asking, just to throw fuel on the fire..
    Are we just looking for PEAK HP.. OR.... are we looking for a big wide power band,
    a ton of torque all throughout. Something that is FUN to drive, and probably faster,
    even with a lower peak HP number.
    Just my thoughts. Just looking for max flow, gets you max HP, but that's it. You're not
    running 6500 rpms ALL the time.. You still have to drive the thing.. You still have to
    pull through to 6500 rpms.
  12. Likes wheelieking71, TeachMePlease liked this post
  13. #29
    Nov 2018
    Minnesota
    236
    153
    123
    Bobw is a smart guy,precisely why som top cylinder head guys do not brag with flow numbers. They really are not a good metric to judge heads by.
    When I find it I donít need it
    When I need it I canít find it!
  14. Likes Winterfalke liked this post
  15. #30
    Feb 2020
    Maryland
    302
    120
    Every cylinder head is different. I don't see much use for cnc unless you are doing exactly the same model of the exact same brand over and over. If you simply want to maximize flow then you have to relieve all the turns/bends. The skill is to open them as large as possible without grinding through to the adjacent port. Even the pros sometimes have to weld a hole closed because they ground a little too much. Casting cores can drift so it is not an exact cnc type Job. The polishing part is self explanatory.
  16. #31
    Mar 2019
    Wisconsin
    3,034
    143
    865
    CNC ported heads from certain manufacturers are very consistent. Engines can be built to a certain "recipe", so to speak, with a predictable outcome especially when dealing with pump gas, E85, methanol, or race gas, combustion chambers get real important.
  17. #32
    Jan 2013
    Gilbert, AZ
    7,397
    9987
    9447
    Huh what?! Nobody ports heads to tune a lean spot. WTF does FI have to do with head porting.
    People port heads for one reason, and one reason only: more power. And the fuel delivery method has nothing to do with it in an N/A engine.
    In order to make more power, one needs more air. No way around it.
    In order to achieve stoichiometry in the quest for power, 99.99999% of the time, air will be the limiting factor. Fuel is the easy part.
    Add a power-adder (turbo, blower, supercharger), and that can skew the equation. And, FI can help with the tuning.
    But said tuning is needed because: more air. Just like modified ports can achieve.
  18. Likes snowshooze, Demon73, 52 Ford liked this post
  19. #33
    Mar 2019
    Wisconsin
    3,034
    143
    865
    Quote Originally Posted by Superbowl View Post
    Places like AFR and Brodix have thier own casting designs that favor CNC porting with thicker castings along with, in some cases, relocated valves.
  20. #34
    Sep 2010
    794
    366
    152
    Quote Originally Posted by standardparts View Post
    I don't give a damn.
    I am just trying to buy models.
    They can tell me what they have for sale.
  21. #35
    Apr 2018
    9,837
    4726
    They have heads for sale. So buy one and scan it.
  22. Likes wheelieking71 liked this post
  23. #36
    Sep 2010
    Oklahoma City, OK
    5,752
    1135
    2529
    May help to know if we're looking for heads for a BBC, LS, Miata, etc.
  24. #37
    Sep 2010
    794
    366
    152
    Quote Originally Posted by Cole2534 View Post
    May help if I could find files.
    That is all I want.
  25. #38
    Jan 2015
    Missouri
    1,642
    239
    1039
    Iíve got files for these
    Don
  26. Likes snowshooze liked this post
  27. #39
    Sep 2010
    794
    366
    152
    Quote Originally Posted by D Nelson View Post
    I’ve got files for these
    Don
    Cool.
    What are they, and is there any sales for them?
  28. #40
    Jan 2015
    Missouri
    1,642
    239
    1039
    Honda grom intake manifolds and the 125 cc pit bikes
    Don
