pharaun159
- Feb 2, 2016
Hey guys, got abit of programming issue. First off let me tell you where im at experience wise. Im a 6 year cnc lathe programmer/machinist. Never learned the old school way on manuals. They stuck me on a machine and i learned the hard way the whole time. Ive ran and programmed Star swiss, mazak dual turns, mazak quick turn 200II, mori seiki sl3, haas sl40, haas ds 30ssy, Track lathes, and now this daewoo puma. I learned on the conversational mazaks first for 3.5 years. dabbled with the swiss at the same time. Later moved to g-code only but it is the weaker of my knowledge, as i only know what ive had to use before. I've never used cam software to make my code. I've only ever either wrote my code on paper, or i use a text editor i bought called "CNC discriminator" that can plot out basic tool pathing. Ok, with that out of the way. Here is what i got.
This shop im at has this daerwoo. Their previous "master programmer" (their words) is the GM now and is my only reference for machine specific stuff. However, from what im seeing, this guy has been copying and pasting from the same program that someone wrote for him for the last 12 years. He has very little understanding. I now have this part to program where i need to pull a part still attached to the bar out.. use the vertical live tools to do some work, then push the bar back, and then part and pick off. I have a couple questions on this.
here is the code im working with. They were clearly picking off slugs with this.
(SUB SPINDLE BAR PULL)
N13(TRANSFER&PART OFF)
G30U0W0
G53B0
G0G40G80G99
M1
M131 (INTERLOCK BYPASS SUB)
M169 (SUB UNCLAMP)
G97S300M3
M213 (SPINDLE SYNC)
G0G54B.1
M86 (TORQUE SKIP)
G31P99G1G98B-.331F50.0(PICK OFF POINT)
M87(TORQUE SKIP CANCEL)
M168(SUB CLAMP)
M31(INTERLOCK BYPASS)
M69(MAIN UNCLAMP)
G0G54B0.0(PICK OFF RETRACT POINT)
M68(MAIN CLAMP)
M111(PARTS CATCHER RETRACT SUB)
M105(SUB SPINDLE STOP)
M5(MAIN STOP) (POSSIBLE ISSUE. SPINDLES CANT STOP AT DIFFERENT TIMES while bar is attached)
M1
First, According to him, the spindles need to be turning to bar pull on this. Thought that was weird and not sure if it is true.
Second if i do have to keep them spinning, can i put both m5 and m105 on the same line to stop them in sync.
Third, this is the first time i've ever seen a "g31p99". Im not sure what that is doing. Im having issues finding anything about it. Its not in my books and reference sheets both personal or with machine papers.
Forth, most of the parts i make have tolerances of +/- 0.0005" or +/- 0.00025". On my length i have an unusual +/- 0.002" I should be able to trust the b axis to hold that correct? Or should i still pick the part off completely and face it on the sub?
I understand that this shows some weak points in my knowledge, but machining education just isnt what it was. What i know i learned through observation and my own foot work. Appreciate any insight you guys can offer.
With respect,
Thank you.
G30U0W0
G53B0
G0G40G80G99
M1
M169 (SUB UNCLAMP)
G97S300M3
M213 (SPINDLE SYNC)
G0G54B.1
M86 (TORQUE SKIP)
M168(SUB CLAMP)
M69(MAIN UNCLAMP)
M68(MAIN CLAMP)
M1
With respect,
Thank you.
