stevensm581
- Sep 7, 2021
So I've got this operator that crashed the machine, continued to watch it run with the broken tool, and waited for some reason to do a tool change then hit E-Stop in the middle of a tool change, then power off the machine with the tool holder down, ...
I'm not even getting an error in MDI when I try to walk it through a manual cycle, at the M81 it just sits there, spindle is oriented, even tried running the spindle, stopping it, then redoing the M19 it still just squats at the M81.
The list below is supposed to be done in order for TS purposes.
M19, M81, M82, M83, M84, M85
I have Hydraulic power,
An M84 should allow me to retract the arm back up into position. In MDI, the screen just sits there when cycle start is pressed.
If an M6 is performed I get the same thing.
I've got all the manuals and there is nothing except the same procedure having you go through the list of the aforementioned M codes.
