datron neo versus haas cm-1
Page 1 of 2 12 LastLast
Results 1 to 20 of 31
    Feb 2017
    511
    8
    164
    Default datron neo versus haas cm-1
    I'm evaluating Datron Neo and Haas CM-1 milling machines. Was hoping I could get some feedback from folks that have experience with these machines and which you would recommend. Both machines match my milling needs and fit my shop size.
    May 2014
    Los Angeles
    455
    82
    Hello.
    I have no experience with either machine but from what I remember from westec, datron does not Ridgid tap.
    May 2017
    Minnesota
    1,207
    1513
    818
    In order for us to help you decide which one's better for you, perhaps you should share some information about what sort of work you intend to do.
    Apr 2015
    Connecticut
    430
    248
    181
    I think I boils down to service at this point. They both fit your needs now will they when one breaks down?
    Feb 2017
    511
    8
    164
    Quote Originally Posted by mhajicek View Post
    Mostly aluminum, high accuracy prototyping, very low volume, small size parts.
    Feb 2017
    511
    8
    164
    Quote Originally Posted by Whysosharp View Post
    This is EXACTLY the kind of info I am interested in. Any experience with either of these manufacturers and their support quality? I will be buying a new machine, so theoretically I get some kind of warranty. They both have field offices nearby.
    Feb 2017
    511
    8
    164
    Quote Originally Posted by plutoniumsalmon View Post
    Hello.
    Hm, that could be a problem, I'll check into that with them.
    Aug 2016
    Ohio
    31
    30
    26
    The datron is really just a router, not a full cnc. The two are very different from each other and also very specialized machines that only excel at specific tasks. Datron - flat parts cut from sheet on vacuum table. CM-1 tiny 5 axis stuff. Both are limited IMHO and cost as much as real CNCs. People new to the industry seem to be the only ones impressed by these machines because they are marketed well and have a good online presence. I would suggest to dig a little deeper.
  9. Likes mhajicek, Laurentian liked this post
  10. #9
    Dec 2014
    CANADA
    British Columbia
    1,287
    361
    590
    Quote Originally Posted by DFrench View Post
    Tell me about it, I built a Cm-1 on the Haas website and the base machine is only $59k which is on the high end of reasonable for a machine that size. The 5 axis option package right next to adds another $42k including the trunnion. I could buy a lot of machine for $102k if I didn't mind a couple chips in the paint and had the space for it.
    The Datrons always looked cool but the tiny rinky dink tool holders reminded me of Tormach TTS, but they did have higher production values and market their machines well.
  11. Likes Laurentian liked this post
  12. #10
    Sep 2018
    Oregon
    402
    158
    143
    what is 'high accuracy' and what is 'small' to you?
  13. #11
    Jul 2016
    New Mexico
    587
    123
    158
    What about a Brother Speedio S300? Really compact machine. 30 taper. Fast, accurate and reliable, and probably in the same price range.
  14. #12
    Sep 2018
    Oregon
    402
    158
    143
    Quote Originally Posted by riabma77 View Post
    I was thinking the same thing. Even with a full 5th axis table an S300 is in the ballpark or cheaper than the CM-1, and is not even comedically comparable.
    Can Datrons do full 5 axis? Is 5 axis needed for your parts?
  15. Likes coffeetek liked this post
  16. #13
    Feb 2018
    Washington
    70
    124
    56
    I was just about to post this. Look into Brother machine.
  17. Likes Laurentian liked this post
  18. #14
    Nov 2006
    Montco, PA
    556
    46
    68
    We looked at a Datron machine two years ago. Very snotty sales rep. Wanted $800 to just do a small test cut for us. And this is after 3 months of talking to them.
    Someone is my industry has one. They hate it.
    Buy a Brother Speedio you will be better off
  19. Likes millNchill, Laurentian liked this post
  20. #15
    Feb 2007
    Boston MA
    1,084
    429
    916
    I am not sure what Daton's niche is? I have a competitor that has one of their machines. They are brand new to CNC and didn't have any point of comparison. I also have a friend who was interested in buying one to make simple 6061-AL parts, but when you compare them to a Speedio, the Speedio blows them out of the water in terms of speed, accuracy, surface finish, production capability and just about everything else.
    If the Datron was a $30k machine, I can see it... but it isn't. It's Speedio money but with a fraction of the performance.
  21. Likes Laurentian liked this post
  22. #16
    Feb 2017
    511
    8
    164
    My problem is that I've got a VERY small space with 35"w by 78"h doorway....the Datron Neo and the Haas CM-1 will both fit into the space. I would LOVE to go with the Speedio, looks perfect for my needs, but I don't see how I can fit it through the door. I'll talk to Brother and see whether the Speedio can be broken down for transport into my space....
  23. Likes Laurentian liked this post
  24. #17
    Sep 2009
    barcelona, spain
    2,458
    552
    1460
    Haas has excellent support, cheap spares, and the highest resale value in the cnc mt industry.
    And about 1000x more machines sold than Datron.
    That said, I partly don´t understand the pretty common obsession with door width.
    Even if You rent, landlords will be very happy if you install a bigger door raising the value of the property.
    3000$ would get me a bigger doorway, new premium metal door installed, in about 2-3 days.
    On a 100.000$ mt purchase, the doorway is ancillary costs.
    I could get a non-premium industrial metal door done myself for about 500$, and have done so.
  25. Likes Laurentian liked this post
  26. #18
    Feb 2017
    511
    8
    164
    Unfortunately, its more than a doorway, its two doorways and a hallway, before I get to a room that has sufficient ceiling height...I am evaluating the doorway resizing thing, but not sure how I get past the ceiling height issues.....maybe I rent a helicopter and drop it through the removed roof
  27. #19
    Sep 2014
    1,934
    1475
    1412
    Quote Originally Posted by drcoelho View Post
    The Speedio S300 is 43 inches wide. The height is really close. You can email me for more information.
    Andy Dukes
    Vice President
    Yamazen Inc
    [email protected]
  28. Likes Laurentian liked this post
  29. #20
    Oct 2011
    Stockholm, Sweden
    146
    56
    I have a CM-1 (OM-1 since it is older but the same thing) since many years. I would say it is a good machine for what it is, if you have small alu or plastic parts with high precision it is a good fit. Small here means that it fit in your palm.
    If you want to remove a lot of material or make parts the size of the table it can be done, the parts will be great but it won’t be fast. Maximum tool diameter is 10mm and with that it is light cuts.
    With this machine and alu/plastic you have to use max rpm and take advantage of that the light cuts results in really low cutting forces. That is hold the parts in really little material, double stick tape etc. and have very little material to take away afterwards.
    A Speedio or Robodrill will remove a lot more material a lot faster (actuelly really a lot), and their tool changes are at least 10 times as fast. The only place I know they are used in production is in the watch industry where the compete with Swiss machines 3 times the price.
    But if space is limited and you use a lot of tiny tools it is not a bad machine. Power requirements are also low and single phase.
    I would only consider the Datron if all your parts are made from sheets, it is a router, a beefed up version of the old Roland desktop mills... The CM-1 is a real mill.
    If you get one DO get the probe package and don't bump the spindle, it is very sensitive.
    I'll gladly answer your question about the machine.
    Regards Staffan
  30. Likes Laurentian liked this post
