dandrummerman21
Stainless
- Feb 5, 2008
- MI, USA
So this might not specifically be cnc related, but wasn't sure if there was something y'all have come up with for something similar in the past.
I have a part made of stressproof material, about 2" OD and 1.7 ID. I am putting a 3/32 slit in it to split it so the ring can collapse.
I am running a 3" HSS concave saw blade, 200rpm 4ipm. "conventional cutting" so the cutter starts the cut on the ID and exits on the OD of the part.
I mount these parts 2 at a time on "arbors" that allow them to hang on top of the jaws, and the jaws clamp directly onto the parts.
Anyway, I am deburring the OD with a chamfer tool in the machine, but I am having a hard time deburring the ID. Currently using a 80 or 120 grit flap wheel 1.5" diameter in a die grinder. I have to do it twice, once one way, and then flip the part and go the other way. And even when I do that, sometimes I "miss" the burr, and gotta do it again.
The real problem is, while I trust myself to deburr these, I am not gonna run it myself, wanna put someone else on it but I have a hard time trusting anyone else to deburr their damn parts right lately (seriously, its been problematic of late). Anyway, I want something a bit more foolproof, while being quick and easy.
I am running 16 pcs at a time (8 arbors in 2 double vises), that runs about 8 minutes. 1500 pcs total at this time. I don't expect the operator to beat that time while loading the next set of pins, but if they were able to deburr and load pins in about 12 minutes, that'd be great (we've run these many times before, only now after years of running have I changed the setup to include deburring!!! lol...)
Slight additional challenge, parts are not super round after slitting, sometimes springing in .030" at the slot, can't really hone them. and surface finish is important, must be 63 or better.
Have tumbler, our media sucks, so if suggesting to tumble, what media would you use? ours just turns our parts muddy, hard to clean off, and just really doesn't do a good job cutting.
Was thinking about some sort of "deburring wheel" like the ones we use on our pedestal grinders, but I don't see them that small?
Was also thinking of trying to slit it with a slightly smaller tool then come back with the 3/32 but don't know if that would work or just cause more grief.
I'm open to suggestions, thanks
